How to find FamilyInstances in linked Rooms?
dantartaglia8696
dantartaglia8696
I have lightingFixtures in my active model that are positioned in linked rooms/ceilings. They are faced based. I cannot seem to be able to determine which rooms these lights exist in. The below code does not return any FamilyInstances in my linked rooms. The bounding box is the correct height and I tried other categories of FamilyInstances (sinks, desks, ect) without success (I commented out the line: .OfCategory(BuiltInCategory.OST_LightingFixtures)). Please let me know if you have any ideas.
P.S. the room I'm passing is from the link and the Document is the active file.
Dan
private List<FamilyInstance> LightingFixtsFromRoom(Room oRoom, Document oDocument)
List<FamilyInstance> oFamilyInstances = new List<FamilyInstance>();
try
BoundingBoxXYZ oBoundingBoxXYZ = oRoom.get_BoundingBox(null);
Outline outline = new Outline(oBoundingBoxXYZ.Min, oBoundingBoxXYZ.Max);
BoundingBoxIntersectsFilter filter
= new BoundingBoxIntersectsFilter(outline);
FilteredElementCollector collector = new FilteredElementCollector(oDocument)
.WhereElementIsNotElementType()
.WhereElementIsViewIndependent()
.OfClass(typeof(FamilyInstance))
.WherePasses(filter);
foreach (FamilyInstance oFamilyInstance in collector)
// Got my light fixtures
return oFamilyInstances;
catch
return oFamilyInstances = new List<FamilyInstance>();
Mustafa.Salaheldin
Instead of that you can get the reference point of the fixtures then using the Room.IsPointInRoom Method you can check if it is in the room or not.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
dantartaglia8696
Thanks for the response. Jim Jia from Autodesk Support contacted me with the below answer as well. I have not had a chance to to test either but I'm sure they will work:
When building BoundingBoxFilter, you should apply the transformation of Rvt Linked instance: The Room.Get_BoundingBox will return BoundingBox in source rvt rather than actual BoundingBox in active document.
        public void GetLights(Autodesk.Revit.ApplicationServices.Application app, Document doc)
            string xpath = null;
            // this is sample code, it supposes the project has one link rvt only..
            // get external file reference so that we can open the link document to get room and its boundingbox
            Autodesk.Revit.DB.Transform trf = null;
            ICollection<ElementId> ids = ExternalFileUtils.GetAllExternalFileReferences(doc);
            foreach (ElementId id in ids)
                Element teme = doc.GetElement(id);
                if (teme.IsExternalFileReference())
                    ExternalFileReference fs = teme.GetExternalFileReference();
                    if (fs.ExternalFileReferenceType == ExternalFileReferenceType.RevitLink)
                        xpath = ModelPathUtils.ConvertModelPathToUserVisiblePath(fs.GetAbsolutePath());
                        RevitLinkType instype = teme as RevitLinkType;
                        FilteredElementCollector temcc = new FilteredElementCollector(doc);
                        temcc.OfClass(typeof(RevitLinkInstance));
                        foreach (var rli in temcc.ToElements())
                            if (rli.GetTypeId() == id)
                                // get transform of linked instance
                                RevitLinkInstance ins = rli as RevitLinkInstance;
                                trf = ins.GetTransform();
                            break;
                        if (null != trf)
                            break;
            // find room in linked Rvt
            RoomFilter rmfilter = new RoomFilter();
            Autodesk.Revit.DB.Document xdoc = app.OpenDocumentFile(xpath);
            FilteredElementCollector temc = new FilteredElementCollector(xdoc);
            temc.WherePasses(rmfilter).WhereElementIsNotElementType();
            foreach (Room rm in temc)
                BoundingBoxXYZ box = rm.get_BoundingBox(null);
                if (box != null)
                    // !!!Important!!! apply the link instance transform to the boundingbox
                    Outline outline = new Outline(trf.OfPoint(box.Min), trf.OfPoint(box.Max));
                    BoundingBoxIntersectsFilter filter = new BoundingBoxIntersectsFilter(outline);
                    FilteredElementCollector mtemc = new FilteredElementCollector(doc);
                    mtemc.WhereElementIsNotElementType().WhereElementIsViewIndependent()
                        .OfClass(typeof(FamilyInstance)).WherePasses(filter);
                    if (mtemc.Count() != 0)
                        MessageBox.Show(mtemc.Count().ToString());
dantartaglia8696
I just got back to this issue and realized Jim's response wants me to open each link in memory to process. There can be numorous Revit links and feel this will take took long. I'm currently using a combination of Mustafa's and Jim's suggestions as well as my approach. (Mustafa mentioned: Room.IsPointInRoom and Jim's room filtering). This is what I have so far, it works in my test models but need to verify on an actual project RVT (you know how that is). Please let me know if you see a more streamlined approach:
private void ProccessStart(UIApplication m_app)
try
// Make sure no other RVTs are open in Revit
if (MultipleRVTsOpen(m_app) == true)
TaskDialog.Show("Process Stopped", "Please only have one file open when running this tool");
return;
// Iterate through each document
foreach (Document oDocument in m_app.Application.Documents)
// Only process links
if (oDocument.IsLinked)
// Create a room collection from rooms in the current link
RoomFilter oRoomFilter = new RoomFilter();
FilteredElementCollector oFilteredElemCol = new FilteredElementCollector(oDocument);
oFilteredElemCol.WherePasses(oRoomFilter).WhereElementIsNotElementType();
// Iterate through each room
foreach (Room oRoom in oFilteredElemCol)
// Only process placed rooms
if (RoomIsPlaced(oRoom) == false)
continue;
// Get all LightingFixtures in the current room
LightingFixtsFromRoom(oRoom, m_app.ActiveUIDocument.Document);
catch (Exception ex)
TaskDialog.Show("Error", ex.Message);
private bool MultipleRVTsOpen(UIApplication m_app)
int intCntr = 0;
try
// Skip linked RVTs and families
if (!oDocument.IsLinked && !oDocument.IsFamilyDocument)
intCntr++;
if (intCntr > 1)
return true;
return false;
catch
return true;
private bool RoomIsPlaced(Room oRoom)
try
// Make sure the room does not contain a location or area value
if (null != oRoom.Location && Math.Round(oRoom.Area) != 0.0)
return true;
else
return false;
catch
return false;
try
// Create a LightingFixture/FamilyIntance collection that exist in the active document
.OfClass(typeof(FamilyInstance));
// Iterate through each instance
foreach (FamilyInstance oFamilyInstance in oFilteredElemCol)
try
// Get the boudning box of the instance
BoundingBoxXYZ oBoundingBoxXYZ = oFamilyInstance.get_BoundingBox(null);
if (oBoundingBoxXYZ == null)
continue;
// Get the center point of the instance (except Z, want to make sure recessed lights are found)
XYZ oCenterPoint = new XYZ((oBoundingBoxXYZ.Min.X + oBoundingBoxXYZ.Max.X) / 2,
(oBoundingBoxXYZ.Min.Y + oBoundingBoxXYZ.Max.Y) / 2,
(oBoundingBoxXYZ.Min.Z));
// Determine if the point exists within the bounding box/room
if (oRoom.IsPointInRoom(oCenterPoint) == true)
TaskDialog.Show("Got lights", "Light family name: " +
oFamilyInstance.Symbol.FamilyName + ", Room name: " + oRoom.Name);
catch
// continue processing
catch
Mustafa.Salaheldin
It seems like your code goes fine. I've not tested it either but it seems right.
Good luck
¯\_(ツ)_/¯
Mustafa Salaheldin
JimJia
Dear Daniel Tartaglia,
I didn't find problems in your code shared though I didn't tested it either. Please let us know if you still have problem on this case.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
