Try to export Lights Geometry without its light source geometry (bulb or cone)
pbobz
Message 1 of 8
pbobz
Hi Fellow Programmers of the Revit API,
Any one knows how to not export the "light source" geometry.
I read somewhere on the forum that you can skip geometry based on solids face matrerial if it's name is "Default Light Source". However, in my case Face.MaterialID is always -1.
And don't see any way to export the light geometry without its light bulb/cone.
Any suggestion ? 🙂
Replies (7)
Message 2 of 8
Revitalizer
GraphicsStyle graphicsStyle = doc.GetElement(solid.GraphicsStyleId) as GraphicsStyle;
if (graphicsStyle != null)
    if (graphicsStyle.GraphicsStyleCategory.Id.IntegerValue == (int)(BuiltInCategory.OST_LightingFixtureSource))
        // light sources geometry
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 3 of 8
pbobz
I tried something similar :
if (gStyle.GraphicsStyleCategory.Name == "Light Source")
       continue;
but without any success.
Hope your BuiltInCategory way will work 🙂
Be right back to tell you,
Message 4 of 8
Revitalizer
whenever possible, you should use the language independent approach.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 5 of 8
Revitalizer
supposing you have a French Revit, the Category's name will be translated (by Revit) into its French equivalent (if it is a top level Category).
Thus, "Light Source" won't work, except you translate it into French...
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 6 of 8
pbobz
Nop, same effect. I keep exporting light source geometries even when I skip those based on graphicstyle.
 foreach (GeometryObject obj in geoElement)
                GeometryInstance geoInstance = obj as GeometryInstance;
                GraphicsStyle gStyle = doc.GetElement(obj.GraphicsStyleId) as GraphicsStyle;
                if (gStyle != null)
                    if (gStyle.GraphicsStyleCategory.Id.IntegerValue == (int)(BuiltInCategory.OST_LightingFixtureSource))
                        continue;
                    ExtractSolid(doc, VRobj, solid, color);
Message 7 of 8
Revitalizer
the GeometryInstance contains futher sets of geometry, it is a container.
Use the approach on Solid level, not on GeometryInstance level.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 8 of 8
pbobz
Excellent !
Thanks for pointing that to me.
It's working like a charm. Thanks for all the advices.
Regards
