How to access picked object from another method
markjvlampad
markjvlampad
Hi there,
i have this code:
//this code is to pickobject
public class sample : IExternalCommand
static AddInId appId = new AddInId(new Guid(""));
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
UIDocument uidoc = commandData.Application.ActiveUIDocument;
Document doc = uidoc.Document;
Reference r = uidoc.Selection.PickObject(ObjectType.Element);
Element e = doc.GetElement(r);
return Result.Succeeded;
//for some reasons, I want to access e from above method and do something with that object.
public void getdatafrompickobj()
having the above codes how can I do that?
cheers,
mark
RPTHOMAS108
Call 'getdatafrompickobj' in Execute method prior to 'return Result.Succeeded', passing 'e' as argument in 'getdatafrompickobj'.
You can also scope the 'e' variable to class level but that seems less wise, since object lifecycle is less clear to me.
markjvlampad
 hi thank you,
when I pass e as my arguments it wont works. I cannot access my Element e.
As was hinted at you could try declaring the element somewhere more accessible to other methods, but you will need to be aware of the object lifecycle, which is more of a c# general issue and less of a Revit issue. Although to some degree, the API is going to affect it as well I suppose. You can also try making it public, static, etc.
 Element e { get; set; }
    if(e != null)
        //Do some code with e
     else
         //Messagebox or something to say nothing was selected
