trigger Property Dialog of a Family through API
Message 1 of 12
Is it possible to trigger the Property Dialog of a Family through API ?
Or open the Type Property Dialog of the Assigned Family ?
Replies (11)
Message 2 of 12
Revitalizer
UIApplication uiapp = commandData.Application;
RevitCommandId commandId = RevitCommandId.LookupPostableCommandId(PostableCommand.TypeProperties);
if(uiapp.CanPostCommand(commandId))
    uiapp.PostCommand(commandId);
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 3 of 12
but how can i pass the family to the dialog ? thank u
Message 4 of 12
Revitalizer
you need to select an Element of the ElementType you want to display.
Edit the UIDocument.Selection before invoking the PostableCommand.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 5 of 12
arnostlobel
Just remember that posting the command should be the last thing your external command does in its Execute method.
Arnošt Löbel
Message 6 of 12
hi, Revitalizer
thank u for your reply,i have tried the UIDocument.Selection function to add a "wall" element to the UIDocument.Selection ,and then call the PostCommand method,it works well ,but i want the type property dialog to show a Family that i havn't  add a instance.i have tried the way below,but the dialog can't show.
Another question how to invoking the properties dialog by assigned family(specially havn't has instance for the family)? thank u
if (family != null)
                //ISet<ElementId> familySymbolIds = family.GetFamilySymbolIds();
                List<ElementId> lelementIds = new List<ElementId>();
                lelementIds.Add(family.Id);
                uidoc.Selection.SetElementIds(lelementIds);
                if (uiapp.CanPostCommand(commandId))
Message 7 of 12
Revitalizer
you need to have at least one Instance of your desired Family placed in your project.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 8 of 12
thank u.i get it
Is it possible to trigger the Property Dialog(the first image of my first post) ?
Message 9 of 12
Revitalizer
PostableCommand.TogglePropertiesPalette
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 10 of 12
thank u  but i wan to triger the properties dialog to react a new loaded family that havn't has any instance , like if if select a familysymbol in the Project Browser then the properties dialog react to the family.
Message 11 of 12
Revitalizer
sorry, no more ideas.
Perhaps you can place a dummy instance in a temporary transaction after loading the family.
But I fear that if you delete it, the properties palette will react instantly and switch to another element's properties; having a void selection, this are the current view's properties.
I think, it's not possible.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 12 of 12
i will have a try ,also hope api open more interface to Access the system command and function thanks a lot ヘ(_ _ヘ)
