Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Transmission Data SetDesiredReferenceData doesn't work well on DWF/DWFx
6 REPLIES 6
btmsoftware
630 Views, 6 Replies
In a plugin, I can change the attached DWF/DWFx using transmission data's
so far so good
However, when I open the project, I get the following error: Some sheets have no markups and will not be loaded
This is weird because if I remove the DWF/DWFx and manually link it again, it works fine so the DWF is correct
The same code works perfectly for Revit and CAD links
Ideas ?
6 REPLIES 6
btmsoftware
in reply to: btmsoftware
A bit more info.
I found out that if the new file is actually a copy of the original file, it works fine. This error happens only if it is a whole different DWF/DWFx
Forgot to mention that I'm using Revit Architecture 2016
jeremytammik
Dear Francois,
Thank you for your query.
Please excuse the delay in answering.
Just for your information, escalating it repeatedly does not help speed up the process.
All it does is pollute our database and confuse our poor human cerebra.
Can you please provide a minimal reproducible case for us to analyse in full depth?
In order to understand exactly what you mean and be able to research possible reasons for the discrepancy between the observed and expected behaviour, we require:
  • A short exact description of what you are trying to achieve.
  • The behaviour you observe versus what you expect, and why this is a problem.
  • A complete yet minimal Revit sample model to run a test in.
  • A complete yet minimal macro embedded in the sample model or Visual Studio solution with add-in manifest that can be compiled, loaded, run and debugged with a single click to analyse its behaviour live in the sample model.
  • Detailed step-by-step instructions for reproducing the issue, e.g. which element to pick, what command to launch etc.
http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Thank you!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
btmsoftware
in reply to: jeremytammik
Hi Jeremy,
1st, I want to apologise for repeatedly escalating.
2nd, excuse the  delay too, got side tracked on other projects....
It seems like my mouse chose this moment to get stuck, just when I clicked the button but I didn't realize immediately.
Got me a new mouse so it shouldn't happen again 😉
I'll prepare all the elements and will post them as soon as I can (crazy times right now)....
jeremytammik
np...
say hello to your new mouse from me.
cheers
jeremy
Jeremy Tammik
The Building Coder
btmsoftware
Hi Jeremy,
Ok, seems like I'm losing it big times. while making a little plugin to demonstrate my issue, I can't reproduce the problem so I guess it has to be in my real plugin. I guess I messed up somewhere and have to find out where.
I'll close the ticket in the support system
sorry for wasting your time
jeremytammik
Dear Francois,
Thank you for confirming that all is OK.
No problem whatsoever.
I was thinking of writing a post explaining how often the preparation of a minimal reproducible case actually ends up solving the problem, so this is a very good example to underline that.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
