Transforming point coordinates
MGO-Norsyn
MGO-Norsyn
Hi all
I would like to ask for advice regarding coordinate transformation in the API.
I've got a number of points (Detail Item's location coordinates) in global systems which I want to describe in a particular family's coordinate system O', see attached picture. O is global origin, O' is the target Detail Item's location coordinates, big crosses are other Detail Item's location coordinates which need to be described in X',Y'.
As far as I understand I need to get the transform from the detail item family located at O' something like this:
Transform trf = O'.Location.GetTransform()
And then apply trf to each point that needs transforming to the new coordinate system. After this, X, Y, Z values returned from the transformed location points will be in the O' coordinate system.
Is this correct?
MGO-Norsyn
Do I have to do something like this: where transform is of the O' family and point is the Location as LocationPoint for points which I need to transform
public static XYZ TransformPoint(XYZ point, Transform transform)
    double x = point.X;
    double y = point.Y;
    double z = point.Z;
    //transform basis of the old coordinate system in the new coordinate // system
    XYZ b0 = transform.get_Basis(0);
    XYZ b1 = transform.get_Basis(1);
    XYZ b2 = transform.get_Basis(2);
    XYZ origin = transform.Origin;
    //transform the origin of the old coordinate system in the new
    //coordinate system
    double xTemp = x * b0.X + y * b1.X + z * b2.X + origin.X;
    double yTemp = x * b0.Y + y * b1.Y + z * b2.Y + origin.Y;
    double zTemp = x * b0.Z + y * b1.Z + z * b2.Z + origin.Z;
    return new XYZ(xTemp, yTemp, zTemp);
MGO-Norsyn
The initial thought was correct.
To describe a series of points in a family's local coordinate system following must be done:
Transform trf = FamilyInOrigoOfNewCoordinateSystem.GetTransform();
trf = trf.Inverse;
Get the transform of the family in origo' and inverse it.
XYZ tPoint = trf.OfPoint(point);
Apply the transform to the points which need to be described. After that X, Y, Z properties of these points return values set in the local system of the family where the transform was obtained (Origo in the first code block).
olena_havatiuk
 thanks,
andreyzr43
Tell me how to return the coordinate system of the project for the point?
