Exception while creating Sweep
mhillis
mhillis
Hello all,
Got a bit of an issue that appears, to me anyway, fairly ambiguous.  I was hoping someone can help me understand what I'm missing.
I'm trying to create sweeps within a Family Document.  I can do this just fine with one, but I need to be able to make as many as I want.  I'm currently using the default Revit profile families for duct, to create my sweeps, they are in the following location.
C:\ProgramData\Autodesk\RME 2014\Libraries\US Imperial\Duct\Fittings\Profiles
My problem happens when I load one of these into my Family and then try to make duplicates of it's Symbol so I can get multiple instances of a connector type.  Again, this works fine when I just load a Family Symbol and use the default one I get, I just can't seem to make any copies.
I get the error "One of the conditions for the inputs was not satified. Consult the documentation for requirements for each argument." when I actually go to create the sweep using a copied instance of a Family Symbol.
The funny thing is, when I don't try to create a sweep it appears the family symbol gets loaded into my Family file just fine, I just can't seem to programmatically make a sweep out of it.
I've attached a screenshot showing the Symbol is being loaded correctly, and a text file that contains the code I'm trying to use.  You'll see two primary routines "WorkingRoutine" and "NonWorkingRoutine". along with any helper functions.
Any ideas why I'm getting this issue?
Thanks!
mhillis
Hello again everyone.
I made a super simple oversight.  After creating the Duplicated Family Symbol I forgot to regenerate the family document.
Regenerating the family document resolved my issue.
One of those days.
