Transfer walltypes to project python
ckepner
ckepner
I'm having trouble creating a python version of https://thebuildingcoder.typepad.com/blog/2015/05/transferring-a-wall-type.html
I want to collect all the walltypes of a project and transfer them into the new open model.
Issue is happening when I try to duplicate the walltype into the new model.
import clr
clr.AddReference("RevitNodes")
import Revit
clr.AddReference('RevitAPIUI')
clr.AddReference("System.Drawing")
clr.AddReference("System.Windows.Forms")
clr.AddReference("RevitAPI")
import Autodesk
import System.Drawing
import System.Windows.Forms
from Autodesk.Revit.DB import *
from System.Drawing import *
from System.Windows.Forms import *
import System
from System.Collections.Generic import *
app = __revit__.Application
doc = __revit__.ActiveUIDocument.Document
class SelectionForm(Form):
    def __init__(self, SelNames):
        self.revname = SelNames
        self.Text = 'Transfer Elements'
        self.label = System.Windows.Forms.Label()
        self.label.Text = "Select Element Type"
        self.label.Location = Point(1, 50)
        self.label.Height = 30
        self.label.Width = 200
        self.count = 0
        self.cb = System.Windows.Forms.ComboBox()
        self.cb.Width = 200
        self.cb.Height = 20
        self.cb.Location = Point(15,20)
        self.cb.DataSource = self.revname
        self.button = System.Windows.Forms.Button()
        self.button.Text = 'Element Type'
        self.button.Location = Point(15,60)
        self.button.Width = self.cb.Width
        self.button.Height = 25
        self.button.Click += self.button_click
        self.Width = self.cb.Width + 50
        self.Height = 150
        self.Controls.Add(self.cb)
        self.Controls.Add(self.button)
    def button_click(self, sender, event):
        self.selected = self.cb.SelectedValue
        self.Close()
def filter_list(revisionlist, search_str):
	passed = None
	for element in revisionlist:
		name = element.Name
		if search_str == name:
			passed = element
	return passed
SelNames = ['Wall Types', 'Door Types', 'Casework Types']
form = SelectionForm(SelNames)
form.ShowDialog()
SelectedType = form.selected
options = OpenOptions()
options.DetachFromCentralOption = DetachFromCentralOption.DetachAndPreserveWorksets
if SelectedType == 'Wall Types':
    FilePath = 'C:\Downloads\\project1.rvt'
    modelPath = ModelPathUtils.ConvertUserVisiblePathToModelPath(FilePath)
    docFam = app.OpenDocumentFile(modelPath, options)
    ElemCol = FilteredElementCollector(docFam).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsElementType().ToElements()
elif SelectedType == 'Door Types':
    FilePath = 'C:\Downloads\\project2.rvt'
    ElemCol = FilteredElementCollector(docFam).OfCategory(BuiltInCategory.OST_Doors).WhereElementIsElementType().ToElements()
elif SelectedType == 'Casework Types':
    ElemCol = FilteredElementCollector(docFam).OfCategory(BuiltInCategory.OST_Casework).WhereElementIsElementType().ToElements()
else:
    print('Select Element Type')
newwalltype = []
newwalls = []
for e in ElemCol:
    tcheck = Transaction(doc, 'transfer element')
    tcheck.Start()
    try:
        eleName = Element.Name.GetValue(e)
        newwalls = e.Duplicate(eleName)
        newwalltype.append(e)
    except:
	newwalltype.append(None)
    tcheck.Commit()
print(newwalltype)
jeremytammik
What issue?
Jeremy Tammik
Developer Technical Services
The Building Coder
Revitalizer
duplicating an ElementType just operates on the same file.
You need ElementTransformUtils.CopyElements to transfer the types from one Revit file to another one.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
