How to find plane on pipe center line?
pochao
Message 1 of 11
pochao
Replies (10)
Message 2 of 11
Kevin.Lawson.PE
Autodesk.Revit.DB.Plumbing.Pipe pipe = Autodesk.Revit.DB.Plumbing.Pipe.Create(doc, pipeTypeId, levelId, startConnector, downstreamConnector);//whatever pipe you want the plane on
ConnectorSet pipeConnectorSet = pipe.MEPSystem.ConnectorManager.Connectors;
List<Connector> pipeConnectorList = new List<Connector>();
foreach(Connector connector in pipeConnectorSet)
  pipeConnectorList.Add(connector);
Plane plane = Plane.CreateByThreePoints(pipeConnectorList[0].Origin, pipeConnectorList[1].Origin, new XYZ(pipeConnectorList[0].Origin.X, pipeConnectorList[0].Origin.Y + 10, pipeConnectorList[0].Origin.Z));
-Kevin Lawson, PE
www.rippleengineeringsoftware.com
Revit heating and cooling load calculations in one click!
Message 3 of 11
pochao
Thanks for your response
Does this case apply? ( Sloped, none vertical, none horizontal)
Message 4 of 11
Kevin.Lawson.PE
Maybe, I'm not sure what your exact requirements are.  I was just giving you something to get started working the problem yourself.
-Kevin Lawson, PE
Message 5 of 11
pochao
horizontal pipe:
connector.Origin.Y + 10
vertical pipe:
connector.Origin.X + 10
Others:
I can't find the third point
Message 6 of 11
Kevin.Lawson.PE
The pipe has two connectors, one at each end, which I'm accessing with
The third point can be something off of that, as you said in the x, y, or z direction.
-Kevin Lawson, PE
Message 7 of 11
Revitalizer
why not
Plane plane = Plane.CreateByNormalAndOrigin(pipeConnectorList[0].CoordinateSystem.BasisY, pipeConnectorList[0].CoordinateSystem.Origin);
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 8 of 11
pochao
Finally, I find this solution.
Dim pipeDirection As XYZ = conn0.Origin - conn1.Origin
Dim normal As XYZ = XYZ.BasisZ.CrossProduct(pipeDirection).Normalize
Dim translation As XYZ = normal.Multiply(10)
Dim thirdPoint As XYZ = conn1.Origin.Add(translation)
Message 9 of 11
Revitalizer
if the Pipe is vertical and pipeDirection equals XYZ.BasisZ (or minus XYZ.BasisZ), the cross product doesn't make sense.
You solution doesn't cover all possible cases.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 10 of 11
pochao
Sorry, only in xy plane.
Message 11 of 11
Revitalizer
no need to implement different case scenarios.
All vectors you need are already present in the connector's CoordinateSystem property:
https://thebuildingcoder.typepad.com/blog/2012/05/connector-orientation.html
So, the Pipe's orientation doesn't matter at all.
Just see my previous answer.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
