Topography Area Surface and Projected Area
Hi!
I'm trying to get the surface of a topography. I've seen that if I select the element in Revit I get a different area than the one I get programming. As you can see in the images.
In Revit the value is 3611,301 m2.
And in Visual  I get the value: 4057,8436
For that I use the next code:
List<listAreas> _listAreas = new List<listAreas>();
FilteredElementCollector topographyElement =
                    new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Topography);
foreach (var VARIABLE in topographyElement)
   var topoElement = doc.GetElement(VARIABLE.Id);// as TopographySurface;
   var area = topoElement.get_Parameter(BuiltInParameter.SURFACE_AREA).AsDouble();
   double areaInMeters = UnitUtils.ConvertFromInternalUnits(area, DisplayUnitType.DUT_SQUARE_METERS);
I have tried to use the TopographySurface Class, but I got the same result.
Does anyone know why the values are not the same? Does this take into account the surface of the lateral faces?
And in that case how could I take these surfaces areas or only the top surface area?
I have tried to take them in the following way (shown in the following code), but it is empty
FilteredElementCollector topographySurface =
new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_TopographySurface);
Thank you and best regards
Lorena
recepagah12
I tried the same thing what you did and I get the true value. Except I select the topography with the user interface. As you did, I tried the code in Autodesk Revit Architecture Sample and it worked. Did you check the values via Revit LookUp tool?
I hope this helps,
Recep.
It works, I don't understand the difference between the two, but it's working.
Thank you very much!!!!
Regarding LookUp tool, I have never used it, I check the results in visual basic directly. Do you think LookUp is better?
recepagah12
I don't know either the difference between projected surface area and
surface area. But for everything related to Revit API, Revit LookUp is a
great tool. You can obtain almost every information in Revit UI without add
extra code. Beside getting values you can learn how to obtain parameters
ans if it is changable or not. Revit LooukUp is a have to tool for a Revit
API developer. Thanks very much to Jeremy Tammik for this great tool. You
can install this tool from github or in Boost Your BIM, you can install one
click install tool.
