This forum is for Revit API/Programming questions - not for product question
mikako_harada
Community Manager Community Manager
Message 1 of 14
mikako_harada
Dear Community,
Revit API forum is for API (Application Programming Interface) questions.
For non-API questions, please choose other forums that is more appropriate. For example,
Installation and licensing:
http://forums.autodesk.com/t5/installation-licensing/bd-p/24
Revit Architecture:
http://forums.autodesk.com/t5/revit-architecture/bd-p/133
(This may include platform product usage questions)
Revit Structure:
http://forums.autodesk.com/t5/revit-structure/bd-p/153
Revit MEP:
http://forums.autodesk.com/t5/revit-mep/bd-p/188
We have received a couple of feedback from our API community expressing that this forum is used for unintended purposes occasionally.
So just wanted to add a note about the purpose of this Forum.
We appreciate your understanding and cooperation.
Mikako Harada
Developer Technical Services
Replies (13)
Message 2 of 14
Revitalizer
Dear ADN Team,
I would display the posting's title in UPPERCASE 😉
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 3 of 14
yes, and make it bling bling, shining brightly so it's the first thing you'll see when you look at this forum. And make an option for people with 0 posts, that when they create a new post, a messagebox appears every 5 seconds asking if it's really and APi related question they are posting here 🙂
Message 4 of 14
mikako_harada
Sounds like you are still seeing non-API questions.  I just added "not for product questions".  Unfortunately, I cannot do anything fancy like finding out the new member.
One thing you may be able to help those is to report a wrong post by using options:
  1. on the upper right of each post, there is a pulldown options menu. You can choose "Report Inappropriate Content",
  2. then in the comment, write the resaon why inappropriate. i.e., wrong forum.
    It will be also kind to point to the right one, such as Revit xxx or Installation and Licensing (which I myself found only recently that a separate forum exists.)
If you don't see anybody responding to the request, please add a comment here. I will try to contact the group who manages the backend system.
Thank you for your patience and your contribution!
Mikako Harada
Message 5 of 14
following the examples in Revit API 2015 for ItemFactoryBase.NewModelCurve Method and I'm having an exception stating curve must be in plane.
Below is my macro code based on the API exampe:
public void createLine()
	UIDocument uidoc = this.ActiveUIDocument;
	Document doc = uidoc.Document;
	Application app = doc.Application;
	XYZ startingPoint = new XYZ(0,0,0);
	XYZ endPoint = new XYZ(10,10,0);
	Line l = Line.CreateBound(startingPoint, endPoint);
	XYZ end0 = new XYZ(1,0,0);
	XYZ end1 = new XYZ(10,10,10);
	XYZ pc = new XYZ(10,0,0);
	Arc a = Arc.Create(end0,end1,pc);
	XYZ origin = new XYZ(0,0,0);
	XYZ normal = new XYZ(1,1,0);
	Plane p = app.Create.NewPlane(normal, origin);
	try
		using(Transaction t = new Transaction(doc, "making a line"))
			t.Start();
			SketchPlane skp = SketchPlane.Create(doc, p);
			ModelLine ml = doc.Create.NewModelCurve(l, skp) as ModelLine;
			t.Commit();
	catch(Exception e)
		TaskDialog.Show("error", "Cannot create a line.\nDetails: \n" +
				                e.Message);
 What am I missing?
Any help is greatly appreciated.
Message 6 of 14
Revitalizer
use
XYZ normal = new XYZ(1,0,0);
Best regarss,
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 7 of 14
thanks for the reply. but still. its not working. still having error that curve must be in the plane even though I already changed to  XYZ normal = new XYZ(1,0,0);
Message 8 of 14
Revitalizer
excuse my error.
Normal must be 0/0/1 since it directs upwards.
Best regards,
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 9 of 14
That worked!
XYZ normal = new XYZ(0,0,1);
 Thank you!
p.s., someone has to update the chm 😉
Message 10 of 14
another solution based on Revitalizer's suggestion:
XYZ normal = doc.ActiveView.ViewDirection;
 thanks again!
Message 11 of 14
Revitalizer
Dear anagnam,
the normal vector of the plane depends on your line's geometry, so both view.ViewDirection and 0/0/1 are solutions for just this case.
I recommend to learn more about vector maths.
Alternatively, there are examples for drawing model curves on the TBC blog, e.g.:
http://thebuildingcoder.typepad.com/blog/2015/04/curved-wall-elevation-profile-and-creator-class-upd...
Best regards,
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 12 of 14
ollikat
*LOL*
I don't know whether it's ironic or what...but it's quite awkward that THE discussion thread which tries to instruct keeping the forum clean is polluted by non related discussion X-D.
Message 13 of 14
Revitalizer
Dear ollikat,
you are absolutely right,
it was a mistake to answer the question instead of pointing out that this is the false thread.
@Admins: please delete or move the off-thread postings to keep the forum clean.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 14 of 14
mikako_harada
Dear community,
Thank you for rightly pointing out about our intention of keeping our forum "clean" and logically organized as our accumurated, long lasting knowledge base.
I will pull this out from the float at the top, and write another one explaining what this forum is about.
Mikako Harada
