Thermal Mass - REVIT
Hi everyone
I´m writing a thesis about BIM and I´m using REVIT.
I´m exploring the REVIT functions although i can´t understand how REVIT finds de thermal mass of a wall.
So my question what is the formula used by REVIT to calculate thermal mass?
Thank you all
Luís
rosalesduquej
Hi Luis,
Most likely you will not recieve an answer on this Forum.
Revit API forum is for API (Application Programming Interface) questions.
I did a quick Search and I found a couple of links that might give you some idea, Sorry I'm not very familiar with the Thermal Mass topic.
http://sustainabilityworkshop.autodesk.com/buildings/thermal-mass
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/beta/CloudHelp/cloudhelp/20...
Hope they Help. Also you could try posting your question on some of the other forums.
For non-API questions, please choose other forums that is more appropriate. For example,
Installation and licensing:
http://forums.autodesk.com/t5/installation-licensing/bd-p/24
Revit Architecture (including common platform product usage questions):
http://forums.autodesk.com/t5/revit-architecture/bd-p/133
Revit Structure:
http://forums.autodesk.com/t5/revit-structure/bd-p/153
Revit MEP:
http://forums.autodesk.com/t5/revit-mep/bd-p/188
Cheers,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
Thank you for your answer
the links you gave me dont mention the formula used by REVIT
I thought that the formula was:
Thermal Mass of a layer= Thickness*specif heat*density
altough the values dont match
Spoiler
Spoiler
thank you anyway
Hi, did you get any answer about your question? I notice the same thing as you and no answer on the interent and from the support...
Thank you
Chloé
