the input subcategory is illegal
frankholidayjunior
frankholidayjunior
when i use particular subcategories with a particular name like "test-place-holder" i get
"The input subcategory is illegal" .....error
if the subcategory has never been added before i can add it fine thorugh code. the next time i go to add the subcategory with that name the same thing occurs. if i repeat this process for say "wash-bucket" it has no problems.
frankholidayjunior
I renamed to the subcategory to placeholder and works fine. Also the same subcateogry name caused no issues in another family of same category. Bizzaro.
frankholidayjunior
So its one of these subcategory names
Appliances
Place-holder
Data
in
electrical and plumbing families
none of the other subcategories do this.
the behaviour is if
1. you delete all extrusions
or
2. recreate the subcategory one time
you dont get the error
3. the next time you try to use the subcategory it errors
none of this occurs for any of the other subcategories.
Is it possible family corruption?
george1985
Hi @frankholidayjunior
I have the same error on Revit 2019.2: the first time when I create the subcategory, and assign it to extrusion/freeformelement, it works without issues. Evert second run of the code raises and error:
'The input subcategory is illegal.'
but no on the creation of the subcategory - but instead on assigning the subcategory to extrusion/freeformelement.
Did you ever manage to find the fix for this bug?
Thank you in advance for the reply.
