The input point lies outside of Revit design limits.
johan_neethling9LA52
Observer Observer
Observer
Observer
When creating Planes in a Revit project, typically using
Plane oPlane = Plane.CreateByNormalAndOrigin(normal, oIntersection);
I get the error:
Autodesk.Revit.Exceptions.ArgumentException: 'The input point lies outside of Revit design limits.
 The point where the plane is inserted is located about
7,21122593 mile
11,60534318 km
from the origin. This is smaller than the Deisgn Limits given in the following document:
https://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-3F79BF5A-F051-49F3-951E-D3E86F51BECC
The same application worked with Revit 2017. Has there been a change in the Design Limits, and how can I resolve this?
jeremy_tammik
Dear Johan,
I repeat what I just said to Dirk in his thread on the same topic:
https://forums.autodesk.com/t5/revit-api-forum/the-input-point-lies-outside-of-revit-design-limits/m...
Oh dear, that sounds problematic. I will gladly discuss this with the development team. Can you share a complete minimal reproducible case for them to analyse, demonstrating the issue, throwing the exception and showing exactly how your normal vector and origin point are defined?
Thank you.
Cheers
Jeremy
