The dimension is the same as the default in revit
dreamofbaby0507
dreamofbaby0507
Hi everybody! Hope everybody help please .
I want the same dimension as the default in revit. it mean:
- the first click 2 references, in revit will display dimemsion directly on the interface.
- next, if the user moves the mouse over, the dimmension will be run until the user clicks.
Thanks all very much !!
(I am a Vietnamese who is not good at English, hope everyone will help me!!)
jeremy_tammik
Are you programming using the Revit API?
Do you want to obtain the default dimensioning behaviour in the middle of your add-in?
If the answer to both of these questions is yes, then you might be able to fulfil your requirements by calling PostCommand to launch the built-in Revit dimensioning command:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.3
You need to exit your add-in code after PostCommand.
You can subscribe to the Idling event to get back into your Revit API add-in context after the dimensioning command has completed.
dreamofbaby0507
Thanks you very much!!
I use RevitAPI . C#
If dim in the usual way I can do it !!
But I want when the dimension is finished, move the mouse, the dimmension will automatically follow. (like in the video:  https://drive.google.com/file/d/18PImXm270Q3i-cx7DH4vfHBznlCMF-dG/view?usp=sharing )
Thanks you!!!!
RPTHOMAS108
If you want to see the hovering ghost dimension incarnated into a living dimension then that feature likely doesn't exist.
Otherwise it is just about adding extra references to the reference array. Revit API is transactional in nature meaning you make a request and it completes the whole request upon commit. You don't often see changes on screen until command finishes. Perhaps you can refresh view between transactions (not tested) and that may work for key stages but there will be no continuous animation of anything (for most things).
