The beam system creation is overlapping with family elements.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have developed a Revit add-in that creates beam systems for selected walls. The beam system is being created properly; however, it overlaps with any family elements placed on the wall. I want the beam system to avoid overlapping with family elements.
1.Required format
2. Achieved format
The beam system created is overlapping with the elements that exist on the wall.
3.Source Code:
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using System;
using System.Collections.Generic;
using System.Linq;
namespace hello
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
public class clhello : IExternalCommand
public Result Execute(
ExternalCommandData commandData,
ref string message,
ElementSet elements)
UIDocument uiDoc = commandData.Application.ActiveUIDocument;
Document doc = uiDoc.Document;
try
Reference wallRef = uiDoc.Selection.PickObject(ObjectType.Element, new WallSelectionFilter(), "Select a wall.");
Wall selectedWall = doc.GetElement(wallRef.ElementId) as Wall;
if (selectedWall == null)
TaskDialog.Show("Error", "Selected element is not a wall.");
return Result.Failed;
Reference faceRef = uiDoc.Selection.PickObject(ObjectType.Face, "Select a face on the wall for the beam system.");
GeometryObject geomObj = selectedWall.GetGeometryObjectFromReference(faceRef);
Face selectedFace = geomObj as Face;
if (selectedFace == null)
TaskDialog.Show("Error", "Selected face is invalid.");
BoundingBoxXYZ wallBoundingBox = selectedWall.get_BoundingBox(null);
List<CurveLoop> exclusionRegions = new List<CurveLoop>();
using (Transaction t = new Transaction(doc, "Create Beam Systems on Wall Face"))
t.Start();
List<List<Curve>> exclusionCurvesL = new List<List<Curve>>();
List<Curve> boundaryCurves = new List<Curve>();
foreach (Edge edge in selectedFace.EdgeLoops.get_Item(0))
Curve edgeCurve = edge.AsCurve();
bool isExcluded = false;
foreach (CurveLoop exclusionRegion in exclusionRegions)
foreach (Curve exclusionCurve in exclusionRegion)
if (edgeCurve.Intersect(exclusionCurve) == SetComparisonResult.Overlap)
isExcluded = true;
break;
if (isExcluded) break;
if (!isExcluded)
boundaryCurves.Add(edgeCurve);
UV midpointUV = new UV(0.5, 0.5);
XYZ originPoint = selectedFace.Evaluate(midpointUV);
XYZ faceNormal = selectedFace.ComputeNormal(midpointUV);
XYZ horizontalBeamDirection = faceNormal.CrossProduct(XYZ.BasisZ);
XYZ verticalBeamDirection = faceNormal.CrossProduct(horizontalBeamDirection);
Plane facePlane = Plane.CreateByNormalAndOrigin(faceNormal, originPoint);
SketchPlane sketchPlane = SketchPlane.Create(doc, facePlane);
BeamSystem horizontalBeamSystem = BeamSystem.Create(doc, boundaryCurves, sketchPlane, horizontalBeamDirection, false);
BeamSystem verticalBeamSystem = BeamSystem.Create(doc, boundaryCurves, sketchPlane, verticalBeamDirection, false);
t.Commit();
TaskDialog.Show("Success", "Horizontal and vertical beam systems created successfully, avoiding doors and windows on the wall face.");
return Result.Succeeded;
catch (OperationCanceledException)
return Result.Cancelled;
catch (Exception ex)
message = ex.Message;
private class WallSelectionFilter : ISelectionFilter
public bool AllowElement(Element elem)
return elem is Wall;
public bool AllowReference(Reference reference, XYZ position)
return false;
using System;
using System.Linq;
namespace hello
ref string message,
try
t.Start();
isExcluded = true;
break;
if (!isExcluded)
t.Commit();
return false;
