textNoteTypeSet in Revit 2016 api
rahalabi
rahalabi
I am upgrading  a script witten in C# for Revit 2012 to Revit 2016,
In in the script there is a usage of txtNoteTypeSet which is obsolete in revit 2016 API
how can we solve this issue?
I am putting down the scipt for reference
   textNoteTypeSet availableTextNotes;
public NewSchedulefrm(TextNoteTypeSet iAvaialableTextNotes, List<LightingFixtureObject> iLightingFixtures)
 foreach (TextNoteTypeSet tnt in availableTextNotes)
arnostlobel
Rahalabi:
Your snippet does not show how did you use the TextNoteTypeSet with RevitAPI so I cannot give you a concrete suggestion. However, as a general approach, wherever the TextNoteTypeSet used to be used, those method are now likely to take (as arguments) or return either IList<TextNoteType> or ISet<TextNoteType>. Therefore it is going to be rather trivial to update your code to comply with the new approach.
For methods that used to return TextNoteTypeSet (if any), you’ll do:
IList<TextNoteType> myList = SomeRevitAPIMethod(...);
For method that used to take TextNoteTypeSet as an argument, you’ll do this:
IList<TextNoteType> myList =  new List<TextNoteType>();
{ .. /*some code to populate the list*/ }
SomeRevitAPIMethod( ... myList ...)
I hope this helps.
Arnošt Löbel
rahalabi
Dear arnostlobel,
thanks for your reply, I will put down the whole script that I am working on it so you will have an idea of what i am talking about, I have done some modifications , what is colored in green is what i modified and what is colored n red needs modification
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using Autodesk.Revit.DB;
namespace Lighting_Fixture_Schedule
    public partial class NewSchedulefrm : System.Windows.Forms.Form
        #region Identifiers
        String _ViewName;
        // modified by ramzi al halaby on 22-07-2015 during upgrade to revit 2016
       //textNoteTypeSet availableTextNotes;
        TextNoteType availableTextNotes;
        TextNoteType _HeaderType = null, _CellType = null;
        List<LightingFixtureObject> lightingFixtures;
        double _ScheduleWidth = 0, _ImageWidth = 0;
        public double ScheduleWidth
            get
                return _ScheduleWidth;
        public double ImageWidth
            get
                return _ImageWidth;
        public TextNoteType HeaderType
            get
                return _HeaderType;
        public TextNoteType CellType
            get
                return _CellType;
        public String ViewName
            get
                return _ViewName;
        #endregion
        //public NewSchedulefrm(TextNoteTypeSet iAvaialableTextNotes, List<LightingFixtureObject> iLightingFixtures)
        public NewSchedulefrm(TextNoteType iAvaialableTextNotes, List<LightingFixtureObject> iLightingFixtures)
            InitializeComponent();
            availableTextNotes = iAvaialableTextNotes;
            lightingFixtures = iLightingFixtures;
        private void TbleWidthTextBox_KeyPress(object sender, KeyPressEventArgs e)
            const char Delete = (char)8;
            e.Handled = !Char.IsDigit(e.KeyChar) && e.KeyChar != Delete && e.KeyChar != '.';
        private void ImgWidthTextBox_KeyPress(object sender, KeyPressEventArgs e)
        private void NewSchedulefrm_Load(object sender, EventArgs e)
            // added by ramzi on 22-07-2015 while upgrading to revit 2016(needs work still)
            List<TextNoteType> noteTypeList = new List<TextNoteType>();
            //List<TextNoteType> noteTypeList
            //    = new FilteredElementCollector(revitDoc)
            //    .OfClass(typeof(TextNoteType))
            //    .Cast<TextNoteType>()
            //    .ToList();
            //load the text styles
            //foreach (TextNoteTypeSet tnt in availableTextNotes)
            foreach (TextNoteType tnt in noteTypeList)
                HeaderStyleComboBox.Items.Add(tnt.Name);
                CellTypeComboBox.Items.Add(tnt.Name);
            createDGVColumns();
        /// <summary>
        /// Creates and Sets the columns for the Schedule DataGridView
        /// </summary>
        private void createDGVColumns()
            try
                ScheduleDGV.AutoSizeRowsMode = DataGridViewAutoSizeRowsMode.DisplayedCells;
                DataGridViewTextBoxColumn TypeColumn = new DataGridViewTextBoxColumn();
                TypeColumn.HeaderText = "Type";
                TypeColumn.AutoSizeMode = DataGridViewAutoSizeColumnMode.DisplayedCells;
                TypeColumn.DefaultCellStyle.WrapMode = DataGridViewTriState.True;
                DataGridViewTextBoxColumn LampColumn = new DataGridViewTextBoxColumn();
                LampColumn.HeaderText = "Lamp";
                LampColumn.AutoSizeMode = DataGridViewAutoSizeColumnMode.DisplayedCells;
                LampColumn.DefaultCellStyle.WrapMode = DataGridViewTriState.True;
                DataGridViewTextBoxColumn DescriptionColumn = new DataGridViewTextBoxColumn();
                DescriptionColumn.HeaderText = "Description";
                DescriptionColumn.AutoSizeMode = DataGridViewAutoSizeColumnMode.DisplayedCells;
                DescriptionColumn.DefaultCellStyle.WrapMode = DataGridViewTriState.True;
                DataGridViewTextBoxColumn ManufacturerColumn = new DataGridViewTextBoxColumn();
                ManufacturerColumn.HeaderText = "Manufacturer";
                ManufacturerColumn.AutoSizeMode = DataGridViewAutoSizeColumnMode.DisplayedCells;
                ManufacturerColumn.DefaultCellStyle.WrapMode = DataGridViewTriState.True;
                DataGridViewTextBoxColumn VoltageColumn = new DataGridViewTextBoxColumn();
                VoltageColumn.HeaderText = "Voltage";
                VoltageColumn.AutoSizeMode = DataGridViewAutoSizeColumnMode.DisplayedCells;
                VoltageColumn.DefaultCellStyle.WrapMode = DataGridViewTriState.True;
                DataGridViewTextBoxColumn KeynoteColumn = new DataGridViewTextBoxColumn();
                KeynoteColumn.HeaderText = "Keynote";
                KeynoteColumn.AutoSizeMode = DataGridViewAutoSizeColumnMode.DisplayedCells;
                KeynoteColumn.DefaultCellStyle.WrapMode = DataGridViewTriState.True;
                DataGridViewTextBoxColumn ModelColumn = new DataGridViewTextBoxColumn();
                ModelColumn.HeaderText = "Model";
                ModelColumn.AutoSizeMode = DataGridViewAutoSizeColumnMode.DisplayedCells;
                ModelColumn.DefaultCellStyle.WrapMode = DataGridViewTriState.True;
                ModelColumn.Visible = false;
                ScheduleDGV.Columns.AddRange(new DataGridViewColumn[] { TypeColumn, LampColumn, DescriptionColumn, ManufacturerColumn, VoltageColumn, KeynoteColumn, ModelColumn});
                ScheduleDGV.AutoGenerateColumns = false;
                BindingSource bs = new BindingSource();
                bs.DataSource = typeof(LightingFixtureObject);
                ScheduleDGV.DataSource = bs;
                //Set the properties
                TypeColumn.DataPropertyName = "FixtureType";
                LampColumn.DataPropertyName = "Lamp";
                DescriptionColumn.DataPropertyName = "Description";
                ManufacturerColumn.DataPropertyName = "Manufacturer";
                VoltageColumn.DataPropertyName = "Voltage";
                KeynoteColumn.DataPropertyName = "KeyNote";
                ModelColumn.DataPropertyName = "Model";
                bs.DataSource = lightingFixtures;
            catch (Exception x)
                MessageBox.Show("Error creating Schedule Data\n" + x.Message, "Data Table Error", MessageBoxButtons.OK, MessageBoxIcon.Error);
        private void OKButton_Click(object sender, EventArgs e)
            if (HeaderStyleComboBox.SelectedItem == null)
                MessageBox.Show("Select Schedule's Header Text Style", "Invalide Header Style", MessageBoxButtons.OK, MessageBoxIcon.Error);
                this.DialogResult = DialogResult.None;
            else if (CellTypeComboBox.SelectedItem == null)
                MessageBox.Show("Select Schedule's Cells Text Style", "Invalide Cell Style", MessageBoxButtons.OK, MessageBoxIcon.Error);
            else if (NameTextBox.Text == "")
                MessageBox.Show("Enter a view name", "Invalid View Name", MessageBoxButtons.OK, MessageBoxIcon.Error);
            else if (TbleWidthTextBox.Text == "")
                MessageBox.Show("Enter Schedule Width", "Invalid Schedule Width", MessageBoxButtons.OK, MessageBoxIcon.Error);
            else if (ImgWidthTextBox.Text == "")
                MessageBox.Show("Enter Image Width", "Invalid Image Width", MessageBoxButtons.OK, MessageBoxIcon.Error);
            else
                //Set Selected Text Notes
                setSelectedTextNotes();
                _ViewName = NameTextBox.Text;
                _ScheduleWidth = Convert.ToDouble(TbleWidthTextBox.Text);
                _ImageWidth = Convert.ToDouble(ImgWidthTextBox.Text);
        /// <summary>
        /// Set the Selected Text Notes
        /// </summary>
        private void setSelectedTextNotes()
            TextNoteTypeSetIterator itor = availableTextNotes.ForwardIterator();
            itor.Reset();
            while (itor.MoveNext())
                TextNoteType current = itor.Current as TextNoteType;
                if (current.Name.Equals(HeaderStyleComboBox.SelectedItem.ToString()))
                    _HeaderType = current;
                if (current.Name.Equals(CellTypeComboBox.SelectedItem.ToString()))
                    _CellType = current;
Revitalizer
TextNoteTypeSetIterator is deprecated in 2016, so forget it.
You can use something like this:
private IEnumerable<TextNoteType> GetTextNoteTypes(Document doc)
    return new FilteredElementCollector(doc).OfClass(typeof(TextNoteType)).ToElements().Cast<TextNoteType>();
And then iterate with a foreach loop through its members:
IEnumerable<TextNoteType> textNoteTypes = GetTextNoteTypes(doc);
foreach (TextNoteType tnt in textNoteTypes)
    // do your stuff here
That's all.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
