How to highlight elements when selecting them
desdinova
Message 1 of 9
desdinova
List<ElementId> elemIdList = new List<ElementId>();
            try
                while (true)
                    elemIdList.Add((uidoc.Selection.PickObject(ObjectType.Element, "Pick a room").ElementId));
                    uidoc.Selection.SetElementIds(elemIdList);
                    uidoc.RefreshActiveView();
            catch { }
hi friends
i want to highlight elements when i am selecting them like ctrl and pick objects
How can i do that in while loop in api?
Thanks in advance.....
Replies (8)
Message 2 of 9
Aaron.Lu
Dear, what about shi:
    try
        while (true)
    catch
Aaron Lu
Developer Technical Services
Autodesk Developer Network
Message 3 of 9
desdinova
Thank you Aaron.Lu
It doesn't work for me.
Message 4 of 9
Aaron.Lu
What is your revit version.
it works for me on Revit 2015.
Aaron Lu
Message 5 of 9
desdinova
I use Revit 2015
Message 6 of 9
Aaron.Lu
Not sure what is the problem...
Attachment is video to demo how it works,
Full code I'm using:
    [TransactionAttribute(TransactionMode.Manual)]
    public class Pickwhile : IExternalCommand
        public Document doc;
        public Autodesk.Revit.ApplicationServices.Application RevitApp;
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            RevitApp = commandData.Application.Application;
            var uidoc = commandData.Application.ActiveUIDocument;
            if (uidoc == null)
                message = "Please open a document";
                return Result.Failed;
            doc = commandData.Application.ActiveUIDocument.Document;
            try
                while (true)
            catch
                var td = new TaskDialog("Info");
                td.MainInstruction = commandData.Application.ActiveUIDocument.Selection.GetElementIds().Aggregate("", (ss, el) => ss + "," + el).TrimStart(',');
                td.TitleAutoPrefix = false;
                td.Show();
            return Result.Succeeded;
Aaron Lu
Message 7 of 9
desdinova
Hi and thank you again...
I want to make selection like this..
Please see attachment.
Regards...
Message 8 of 9
Aaron.Lu
I think my demo code could do what you want.
if not, would you let me know what is the problem? e.g. errors or behaviors you not expected.
and another choice is to use PickObjects() method. Did you try that?
Aaron Lu
Message 9 of 9
desdinova
Thank you again
PickObjects() method does what i want...
