Text Note - baseDirection Weird Number
Julian.Wandzilak
Julian.Wandzilak
I was playing recently with text notes and was rotating them a little bit. One thing I need some help with/clarification.
BaseDirection - Revit Lookup shows values between -1 and 1. I was hoping to use it to make sure that text notes are horizontal or vertical. The thing is that it didn't worked.
So please find below the printscreent:
To achieve it I manually rotated the textNote 90 degree with its handle - Lookup is showing correctly 0, 1, 0 - but when I collected it and check it with my code I end up with this weird number which is visible on the form.
TaskDialog.Show("TEST", $"TEXT NOTE ID: {textNote.Id} \n BASE DIRECTION X : {textNote.BaseDirection.X} \n, BASE DIRECTION Y : {textNote.BaseDirection.Y} \n  BASE DIRECTION Z : {textNote.BaseDirection.Z} \n ");
blog: w7k.pl more about me: Linkedin Profile
My add-ins for Revit: Drafter(180+ scripts) & Leveler
jeremy_tammik
Dear Julian,
There is nothing strange about that at all.
On a digital computer working with real numbers represented as doubles or floats,
2.77555756156289E-17 is exactly the same thing as 0.0.
Please read up on precision and the need for fuzz:
Julian.Wandzilak
Thanks! Sometimes I need someone to point to me things which should be obvious 😉
jeremy_tammik
Me too! Happy weekend.
