Message 1 of 9
From the Revit UI I can align a point with a slanted reference and lock it, as I show in the image sequence, however from the API I have not been able to create the constraint, the error is 'The two references are not geometrically aligned so the Alignment cannot be created.
Parameter name: reference2'
I created the reference2 variable with ParseFromStableRepresentation from GetEndPointReference(0).ConvertToStableRepresentation(doc), the stable String is the same as what RevitLookup shows when I check the constraint from the user interface, but it doesn't work from the API.
What could be the error?
Inclined reference
Point
Constraint
Mauricio Jorquera
Developer Advocacy and Support +
