tee connecor
tee connecor
tee connecor
I have developed the Add-in to split the pipe depending on the cut lengths and places the couplings automatically according the pipe types.
If tee connector is connected to pipe, the split is happening in opposite direction, I debugged and found the reason for the issue, i.e., start location of the pipe is not proper.
Please Refer the below images:
And one more thing is happening here, as I observed if I give the pipe length above 1200mm to split it is fine.
I am unable to find solution, Can anyone please help me to solve the issue?
Thank you very much in advance.
jeremytammik
No.
It is extremely improbable that anyone will be able to help without you providing a lot more information.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
