Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Tags and Element
3 REPLIES 3
sonicer
365 Views, 3 Replies
Tags and Element
sonicer
How can I ease get all tag types for selected element?
Example If I select Wall Element need get all wall tag types?
Which paramater in wall is link to wall tag?
thx
Tags and Element
thx
3 REPLIES 3
naveen.kumar.t
in reply to: sonicer
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @sonicer ,
1)start the transaction
2)Select the element
3)
ElementId eid;
IList<ElementId> eids=doc.Delete(eid) as IList<ElementId>;
4)roll back the transaction
5)
ElementId catgeoryID = null;
foreach(ElementId id in eids)
         Element e1 = doc.GetElement(id);
          if(e1.Category.Name.Contains("Tag"))
               catgeoryID = e1.Category.Id;
ElementCategoryFilter ECF = new ElementCategoryFilter(catgeoryID);
//contains all the tag types of selected element
FilteredElementCollector tagcollector = new FilteredElementCollector(doc).WherePasses(ECF).WhereElementIsElementType() as FilteredElementCollector;
 I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Hi @sonicer ,
3)
ElementId eid;
5)
 I hope this helps.
Naveen Kumar T
sonicer
in reply to: naveen.kumar.t
sonicer
Your code is find all tags linked to element.
But I need get all Tag types list. Not tag family instance created in project.
thx.
thx.
naveen.kumar.t
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @sonicer
1)select the element
2)this below code will list the tag types for the selected element
suppose if a wall element is selected this code will return the wall tag types.
Element e;
                Category C = e.Category;
                string categoryName = C.Name.Remove(C.Name.Length - 1, 1);
                string categoryTagName = categoryName + " " + "Tag";
                FilteredElementCollector coll = new FilteredElementCollector(doc).OfClass(typeof(Family));
                foreach(Element e1 in coll)
                   Family f = e1 as Family;
                   if(e1.Name.Contains(categoryTagName))
                        //contains tag types for selected element
                        ISet<ElementId> famSymIds = f.GetFamilySymbolIds() as ISet<ElementId>;
I hope this helps.
Naveen Kumar T
Hi @sonicer
Element e;
I hope this helps.
Naveen Kumar T
