System.TypeLoadException: Could Not Load Type, is the exception I get when Im trying to load my own class libray compiles with Visual Studio
eduardooost
eduardooost
Im getting this error message when executing an external command that references a class library that I compiled using Visual Studio and .NETframework 4.8.
That class library itself was compiled using Visual Studio and .NETframework 4.8, and works fine when I execute it. Next I'll share an image of the working script.
But when I reference this library into another project, I get this message:
System.TypeLoadException: Could not load type 'BIMIQS_modeling_from_autocad_drawing.BIMIQs_default_generic_variables' from assembly 'BIMIQS_modeling_from_autocad_drawing, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null', at Test.Main.Execute...
Does somebody knows how to fix this problem? Thanks in advance!
caroline.gitonga
Hi @eduardooost ,
This does not seem to be a Revit API exception but a .NET one. From afar this looks like referencing mixup to your class library. You could take a closer look at your project references, your web.config file and your .dll versions to make sure that all your references are correct.
Also, take a look at this thread with exact same issue, see if yu could get any insights: https://stackoverflow.com/questions/124841/could-not-load-type-from-assembly-error to solve it
Carol Gitonga, Developer Advocacy and Support, ADN Open
eduardooost
Thank you so much Caroline. Your response was very helpful. It helped me to see that the problem was in the connection between the class libraries.
I think that the problem was the compiling architecture of the class library and of the script that referenced it.
I canged the build platform to x64 in all build configurations on both scripts and it was able to load the first class library.
