- Mute
- Permalink
- Report
I have made much progress in Getting the Sweep Profile to align. Though I think that I am having to input much effort in terms of creating workaround methods to realign something that has already been built as a model-in-place sweep within a project document. Here are the steps I am going through, simply.
1. Get a Sweep from a Project Document
2. Iterate through the pathSketch.Profile and build a curve array...
foreach (CurveArray curveArray in sweep.PathSketch.Profile)
foreach (Curve curve in curveArray)
if (pathStart == null)
pathStart = curve.GetEndPoint(0);
firstPathCurve = curve;
pathSketch.Append(curve);
3. Create a profile CurveArrArray offset from the centre of the first segments sweep path, if i do not do this step the sweep wont form correctly....
private static CurveArrArray CreateCoplanarProfile(CurveArrArray sweepProfile, XYZ direction, double length)
CurveArrArray coplanarProfiles = new CurveArrArray();
foreach (CurveArray curveArray in sweepProfile)
CurveArray offsetCurveArray = new CurveArray();
XYZ startPoint = curve.GetEndPoint(0);
XYZ endPoint = curve.GetEndPoint(1);
XYZ offsetVector = direction * length * 0.5;
XYZ offsetStartPoint = startPoint + offsetVector;
XYZ offsetEndPoint = endPoint + offsetVector;
Line offsetLine = Line.CreateBound(offsetStartPoint, offsetEndPoint);
offsetCurveArray.Append(offsetLine);
// Add the offset curve array to the coplanar profile.
coplanarProfiles.Append(offsetCurveArray);
return coplanarProfiles;
4. Using the new Profile CurveArrArray that is at the start of the first segment, I rotate the profile into the XY Plane...
private static CurveArrArray CreateTransformedProfile(Document doc, CurveArrArray curveArrArrayProfile, XYZ normalPath, XYZ originPath)
using (Transaction t = new Transaction(doc, "Create Transformed Profile"))
t.Start();
Transform transform = ConvertXYZProfileToXYProfile(normalPath, originPath);
CurveArrArray transformedProfile = new CurveArrArray();
foreach (CurveArray curveArray in curveArrArrayProfile)
CurveArray transformedCurveArray = new CurveArray();
transformedCurveArray.Append(curve.CreateTransformed(transform));
transformedProfile.Append(transformedCurveArray);
t.Commit();
return transformedProfile;
private static Transform ConvertXYZProfileToXYProfile(XYZ normal, XYZ origin)
double angle1 = XYZ.BasisZ.AngleTo(normal);
XYZ axis1 = normal.CrossProduct(XYZ.BasisZ);
Transform transform1 = Transform.CreateRotationAtPoint(axis1, angle1, origin);
double angle2 = normal.AngleTo(XYZ.BasisY);
double angleOffset = IsOppositeDirection(normal, angle2);
XYZ axis2 = normal;
Transform transform2 = Transform.CreateRotationAtPoint(axis2, angle2 + angleOffset, origin);
Transform transform = transform1.Multiply(transform2);
return transform;
5. Rotate the CurveArrArray Profile so that it is correctly oriented. The curveArrArray profile rotation requires an offset to get the rotation angle correct depending on the original rotation of the sweep path? in plan according to my testing I had to rotate many times and create this method to force the rotation of the sweep profile in the family to be correct.
private static double IsOppositeDirection(XYZ normal, double angle2)
XYZ cross = normal.CrossProduct(XYZ.BasisY);
if (cross.Z > 0)
TaskDialog.Show("direction", "The angle is to the right of the Y axis");
return Math.PI;
else if (cross.Z < -0.001)
TaskDialog.Show("direction", (180 / Math.PI * angle2).ToString() + "The angle is to the left of the Y axis");
return Math.Abs(angle2 - Math.PI / 2) < 0.001 ? 0 :
(angle2 < (Math.PI / 2) - 0.001) ? -(Math.PI * 1.5) :
(angle2 > (Math.PI / 2) + 0.001) ? (Math.PI * 1.5) :
0;
else
TaskDialog.Show("direction", "The angle is either zero or 180 degrees");
return Math.PI;
6. I might be near to the end now, or maybe I am just going to find one more hurdle?
However if in the project document i offset the sweep from the 0,0,0 point there is one more erroneous offset of the profile orientation away from the sweep Path to solve. You can see in fig 1, the middle line is the sweep path and the bottom image fig2, the offset of the profile ion the family, where the sweep path behaves and does not move. this erroneous offset occurs in all directions when the path is moved away from the 0,0,0, except if the sweep is moved upwards on the y-plane.
fig1.
fig2.
My Question is is all this extra code necessary or am I missing the correct method to rotate the Sweep Profile into the XY plane of a family document? If you know a better method or if i am missing something please direct me to the post or even just let me know as I would really like a simpler more reliable method.
