Surface in columns
Surface in columns
Hello everybody,
I am checking the surface of two columns. One one of them is a circular section and the other a square column.
The dimensions of the rectangular section is 0.475x0.61x4, which means a surface of 9.2595. However the area parameter gives 4.63, exactly the half.
In the case of circular section, has a radio of 0.30 and a length of 4.0, so its area is 3.911. But its ara parameter has a value of 1.956, it is half again.
Someone could say me  why it happens. I reckon the area parameter is the surface of column, am I wrong?, it is other area?.
Javi
Have you checked if the units are correct? By default, Revit API gives you the result in inches, for example.
Try to add this to your code:
Area = UnitUtils.ConvertFromInternalUnits(area.AsDouble(), DisplayUnitType.DUT_SQUARE_METERS);
where area is your parameter.
Cheers
Ruben
RPTHOMAS108
As far as I can tell surface area isn't a built in parameter of a structural column family.
If you are talking about parameters associated with the section shape then these are filled in by the family author. If you are talking about another parameter (based on formulas) then the family author created those and Revit makes no judgement about their accuracy. You can edit family to see what is perhaps being done wrong.
Unless you can indicate the built in parameter these are associated with?
I checked , is not a problem of units. But thanks for your answer
Javi
I will check the BuilInParameter. Thank for your answer
Javi
I've checked that myself and I think i know what you mean.
This post can clarify a bit: https://forums.autodesk.com/t5/revit-api-forum/door-and-window-area/m-p/7853331#M29493
I've tried now and the Area of a column is the total area of the solid:
(i.e.    [B+H] x 2 x height +                BxHx2)                        / 2
    (area of the lateral      + area of top/bottom of column ) / 2
e.g. a column have B=0.5 m, H=1m and height of 4m. The area will be 6.5m2
The same thing is for beams.
Basically, the are that Revit shows is the area of the total surface of the column divided by 2. Why is that? I don't know...
So, if you want to obtain the true section area you have to first obtain the B, then the H and then multiply (square column). For the circular, you just need the pi x R^2
Cheers
Ruben
RPTHOMAS108
If you are speaking of the parameter below then I don't think it holds true that it is always half the actual surface area. I have this column that magically takes up no space at all (I section perhaps).
This parameter is not something inherently useful to the structural framing/columns categories concerned it would seem. I think we need to see if such things are visible in the UI as that helps certify their fitness for purpose in terms of being information for end user.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
