Surface automatic generator
BenoitE&A
BenoitE&A
Hi all,
I have an issue that is close to the existing Revit tool that generates all the rooms automatically.
So here is what I do :
- I use a given model with walls of any types and width
- I select the walls I am interested in
- I want the surfaces enclosed by these new walls.
They are different of the Rooms since I selected fewer walls than in the global model.
Ideally I would create a SpatialElement object for each surface and link it to the surrounding walls.
The question is : what is the best solution ?
Obviously when they designed the automatic room generator Revit programmers had this issue. Any idea how this was solved?
Thanks by advance
Benoit
Benoit FAVRE
CEO of etudes & automates
www.etudesetautomates.com/
BenoitE&A
Here are a few comments that explain the paths I followed :
- either I try to create a plan circuit which encloses a surface, using for examples walls intersecting each other. But I don't figure out which object I should use once I have my circuit to get the given surface ;
- either I use methods like ReferenceIntersection to follow a given wall and turn around my walls. This sounds more reliable but I don't get how to follow walls going outward (which are not intersected by my ray using ReferenceIntersection).
So in fact there are 2 questions in 1.
Benoit FAVRE
jeremytammik
Dear Benoit,
Thank you for your interesting query.
I have no idea how the built-in Revit room generator is implemented.
Am I right in assuming that your problem is entirely embedded in a 2D plane, e.g., in the XY plane?
Maybe it would help if you describe your exact needs in a more abstract fashion.
Then it might very well map easily to existing computational geometry algorithms:
https://en.wikipedia.org/wiki/Computational_geometry
Can you simplify your walls to be simple straight lines?
And the desired surfaces to be polygons using these lines as their edges?
You may need to make use of 2D Boolean operations and adjacent area analysis, which The Building Coder has already discussed in some depth:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.28
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
BenoitE&A
Hi Jeremy,
Thanks for the kind answer. It does not help me much in this topic but anyway...
If you get to know how the room generator is implemented (or who implemented it) I would appreciate the answer !
Sincerely
Benoit
Benoit FAVRE
