Suppress Model Upgrade Window
Hi all,
I've had a bit of a look around and I'm wondering if anybody has come up with a way to suppress the model upgrade dialog window when using Document.LoadFamily() to allow for silent loading of models in the background?
Cheers,
Adam
I too am interested in this solution
I did not find any resource on this 😞
jeremytammik
The Windows API will allow you to do almost anything you want with windows, dialogues and forms:
https://duckduckgo.com/?q=windows+suppress+splash
https://duckduckgo.com/?q=windows+suppress+modeless
The Revit API will probably not help you in this case.
Cheers,
jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
