Suddenly Slow Debugging, Revit 2017 & VS 2015
Ryan
Ryan
Just the other day, i noticed when attaching to Revit to debug through the add in manager that it was taking longer than normal to load all the symbols for debugging.
I have just my code turned on, but it seems to get progressively longer. I've tried restarting, still the same. Is there some sort of cache to empty?
Another option other than just my code that turned on or off?
Thanks!
matthew_taylor
Ryan,
You're not alone.
This hasn't annoyed me enough to investigate further at this stage though. It may be a good one for stackoverflow.com, but please report back if you find out an answer! 🙂
-Matt
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Ryan
Good Idea, Ill post there to
Ryan
Well Ill be...
Debug->Options->under Symbols-> Unchecked Microsoft Symbol Servers.
I guess it got checked at some point??
That's what i get for not being a programmer!
