HI,
I am trying to access all the Rebar numbers in my document..
Usually I do this by accessing the elements parameter (rebar number) and withdraw the value.
In the case of varying rebar set, I can't find the values inside of the rebarset. Is this value not available ? ??
Is there any other way of retrieving all the numbers ?
The use case is when I Want to duplicate a schedule, which has a filter on Rebar numbers, and I try to create multiple schedules with
series of rebar numbers (1-20, 21-40... ) to put these schedules on sheets.. Then I need all the available values, so that I can populate a combobox..
Daniel
