Style and Display panel missing under the Manage Tab
I was working on a project and need to change the cut plane for a certain style of wall, only to discover that style manager was missing. In fact the entire Style and Display panel was missing! (screenshot attached below). Any solutions?
Thank you in advance,
jeremytammik
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Thank you,
I posted it over to the Architecture forum.
