Structural Material Name
Tripler123
Tripler123
Hello everyone,
I would like to know if there is a way to get the name of the structural material of walls or Floors.
jeremytammik
That's a weird question, because your screen snapshot of RevitLookup clearly shows that the answer is YES.
Jeremy Tammik
Developer Technical Services
The Building Coder
Tripler123
    public static List<string> MaterialInfo(String elemento)
            List<string> DataCbm = new List<string>();
            List<Element> Materiales = new List<Element>();
            List<string> strs1;
            foreach (Element el in lstElement)
                if (Util.ParameterToString(el.LookupParameter("Elemento")) == elemento)
                    ICollection<ElementId> materialIds = el.GetMaterialIds(false);
                    strs1 = new List<string>();
                    strs1.Clear();
                    foreach (ElementId materialId in materialIds)
                        //Materiales.Add(docGeneral.GetElement(materialId));
                        strs1.Add(docGeneral.GetElement(materialId).Name);
                        DataCbm.Add(strs1[0]);
            var query = from item in DataCbm
                        let palabra = item
                        group item by palabra into g
                        select new { Key = g.Key, Values = g };
            List<string> lista = new List<string>();
            foreach (var item in query)
                lista.Add(item.Key);
            return lista;
Thanks for your reply yeremy.
I have tried to implement this code where I get the list of materials used in selected items. But it is very bad as I try luck. Some advice to get directly the name of the structural material that an element uses. One method would be helpful.
Thank you,
