How to access/edit existing Schedule data cells with the API?
Ideally I would like to be able to create a Schedule from scratch with the four columns I want, but that part can be done with the Revit UI almost as easily. The thing I would like to do is be able to number sheets in a Sheet Schedule so that they are then ordered by those numbers. Basically sheets numbered Txxx come first, then Zxxx, then ENxxx and so on. I can write the logic to order them the way we need them, but I just don't know how to access and edit the text within the cells of the schedule to do this. Also if a sheet gets added to the project, I would like the schedule to correctly number it according to these rules. Not sure if that part is doable, I could always just create a new schedule if sheets are added.
I attached an image. So right now we have to manually enter the numbers in the "Sheet # in contract" column. I would like a macro that looks at the sheet number column, orders all of them according to our conventions(in this example T sheets first, A second, S third etc), numbers them once they are ordered, and then fills those numbers in the "Sheet # in contract" column. So yea basically I would like to know how to access and edit that raw text in those data cells.
If this can be done through the standard Revit UI even better, our office has just been numbering hundreds of sheets one by one on schedules for years now.
