strange error intersect method
AndrewButenko
AndrewButenko
Hello!
I have two arc :
ar1 - Beg (74,8115396335499 ; 41,2888487663369)
        End (74,6947991545691 ; 40,5049574569469) LineType=Autodesk.Revit.DB.Arc
ar1.Radius  - 77.23866913504196 Double
ar1.Center {(-1.641966087, 52.273996595, 0.000000000)} Autodesk.Revit.DB.XYZ
ar2 Beg (74,9202306615204 ; 42,0738966532894)
      End ( 7 4, 8 1 1 5 3 9 6 3 3 5 5; 41,2888487663369) LineType=Autodesk.Revit.DB.Arc
ar2.Radius 77.238669139034229 Double
ar2.Center {(-1.641966091, 52.273996596, 0.000000000)} Autodesk.Revit.DB.XYZ
I have error  "The intersection result could not be computed" in the command : ar1.Intersect(ar2).
What problem?
jeremytammik
Dear Andrew,
Is the issue you report related to the discussion we recently had on SetComparisonResult incorrectly returns Equal with elliptical arcs?
https://forums.autodesk.com/t5/revit-api-forum/setcomparisonresult-incorrectly-returns-equal-with-el...
If so, it is already being looked at.
If not, please provide a reproducible case for me to pass on to the development team for analysis:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
RPTHOMAS108
 Apparently exception of that description relates to element not being in the right state but I don't know what that means.
You have a negative radius but I guess that is just a misrepresentation here?
