Starting transaction from external application - VB.net
JCMaia
JCMaia
I know this is an old question, I browsed through the solution but I am still having a lot of trouble trying to commit changes to a global parameter from an external application.
 Can someone help me figure it out what code should i place in this module,  to be able to make this transaction ?
below is my code.. I simplified it to make it more easy to focus on a solution 🙂
Module Module1
Public Sub Set_global_param()
        Dim GPlist As ISet(Of ElementId) = GlobalParametersManager.GetAllGlobalParameters(Revit_doc)
        For Each item As ElementId In GPlist
            Dim gpParam As GlobalParameter = TryCast(Revit_doc.GetElement(item), GlobalParameter)
            Dim gpName As String = gpParam.Name
            If gpName = "Param1" Then
                gpParam.SetValue(New DoubleParameterValue(111))
            End If
        Next
    End Sub
End Module
Accepted solutions (3)
jeremy_tammik
You need to use an external event to obtain access to a valid Revit API context within the external event handler when driving Revit from a modeless context:
JCMaia
@jeremy_tammik  thank you very much for your reply.
I tried to implement  the solution, but in the end wasn't able to make it work. I recognize that this is probably due to my inexperience in the Revit API and programming.
I tried to implement the classe's ExternalEventExample, ExternalEventExampleApp and ExternalEventExampleDialog, after translate them from c# to vb .. but i was not successful
I attached my project to this reply and a Revit model, if you could take a look I would be extremely grateful.
I simplified the solution to the bare basic so its easier to analyse.  I am using VS 2022 and Revit 2023
For context, the main use of the app will be to read parameters from several excel files and our ERP system (This part is working) , and use them to updated a Revit model.
JCMaia
I have figure it out a solution to my problem, check the attached file.
hope it helps someone 😊.
