Stairs Attributes urgent
Hi
I am using Revit with c#.
I want get the elements of the stairs like dimensions, height,width etc.
I can see these in the revit but unable to fetch through c# code.
Will someone please reply as soon as possible it's urgent.
I work with Revit MEP but let see if I can help you.
First I would say create a filter for your stairs
CreationFilter cf = app.Create.Filter;
Filter f1 = cf.NewCategoryFilter(bic);
Next create a List to store the returned stair elements
List<Element> Stairs = new List<Element>();
Then call the active document to get the stairs
Document doc = commandData.Application.ActiveDocument
doc.get_elements(f1, Stairs );
Now you can parse through all of the elements returned for your parameters
Foreach (Element stair in Stairs)
foreach (Parameter param in stair.Parameters)
string name = param.Definition.Name;
string value = param.AsValueString
Hope this helps
