Spot Elevation only bottom displaying text
BradOatOlsenPerformance
see the screen cast of the problem.  The text reads the correct elevation until I click to place the note....
Bradley Olsen, P.E.
Intel i9-9900K (8 cores O.C. to 5.3 GHz)
32 GB Ram
(2) Quadro P4000 in SLI
jeremytammik
From your very brief description, I assume your question has nothing to do with programming.
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
sorry.  I intended to attach the screen cast....seen here.
Bradley Olsen, P.E.
32 GB Ram
