Splitting Duct using the API
mhillis
mhillis
Hello everyone,
Looking for an update on something.  I would like to use the Split Element tool to split some Duct that I am inserting using the API, however; from all the resources that I'm seeing, this is impossible.  I'd need to, more or less, do this manually.
Is this still true?  If so, when can we expect to see this implemented into the API?
Edit:  If it's still not possible to envoke the Split Element routine using the API, I suppose I'd need to still manually insert each invidual piece and then put a union between them?
Thanks.
Charles.Piro
The function Split is not accessible with API.
The only solution is to recreate the fonction.
For split a duct, you must :
1) select a point on a duct
2) create two duct with a space between them (0.001)
3) Insert an union between the connector
Smiley Wink
PIRO Charles
Developer
PIRO CIE
Linkedin
mhillis
Smiley Wink
That's the answer I was afraid of.  Hopefully someone from Autodesk could elaborate when we might see this implemented into the UI?
mikako_harada
Hi Mhills,
A side note -
In the effort to better organize and bring more visibilities to our communities, we started Idea Station:
http://forums.autodesk.com/t5/revit-ideas/idb-p/302/tab/most-recent
Feel free to add your wish there. This way, you may have somebody joining you to raise the voice for needing this feature.
When you make a new post, there is a category "API". Make sure you choose it.  We (ADN team) will be monitoring API category.
Mikako Harada
Developer Technical Services
RickyBell
Victaulic has a tool for splitting pipe, duct, and conduit.  The latest version will split Fabrication Ductwork and Pipework.
www.VictaulicSoftware.com
mikako_harada
Hi Ricky,
Very cool.  Thank you for sharing. You should put it on the Revit App Store, too 😉
    http://revitappstore.com
More visibility and easy to find.
Mikako Harada
