Split section
Split section
l.virone
Split section
l.virone
I'm trying to make a plugin to create vertical property lines in SectionView. To do it, I use the plane of the Section which I intersect with the PropertyLine Elements on XY plane and I create vertical 2D line where they intersect. This works but my problem is how handle splitted section? Is it a way to get the differents planes? Is it a way to get the geometry of the section line in ViewPlan?
EDIT: I found this previous topic but they didn't find any solution, I hope the access to sections geometry will be added to the future API versions: https://forums.autodesk.com/t5/revit-api-forum/split-segment-of-a-view-section-via-api/m-p/10081136/...
moturi.magati.george
Hi @l.virone,
Whenever you require new or enhanced functionality, the Revit Idea Station is the place to go.
Please search there for a corresponding wish list entry for the suggested functionality and add your comments to it, or create a new one, if none already exists:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
Tag it as an API wish:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302/tab/most-recent/label-name/api
Ensure it gets as many votes as possible to underline its importance to you and the rest of the developer community.
The Revit Idea Station is currently one of the main driving input forces for Revit API enhancements.
The Revit development team look there. Your comment here in the discussion forum might be overlooked.
  Moturi George,     Developer Advocacy and Support,  ADN Open
