Specify System Type (Hydronic Supply) Pipe Type
Hello
Is it possible to programmatically edit the Mechanical Settings? I would like to specify the Hydronic Supply pipe type (see the screen capture below for a clearer example of the property I would like to set).
I have referred to the Revit Equinox API CHM and searched the online documentation but I haven't found a method or class pertaining to this area. Any ideas how I can set this information?
jeremytammik
Dear sam.z,
Equinox does not exist. That is an obsolete confidential code name. I suggest you use the proper product name, so people can understand what you are talking about.
Looking at the standard Revit 2014 API documentation, I can see some sample code for the ConnectorElement.CreatePipeConnector method that creates a hydronic supply pipe connector and references the PipeSystemType.ReturnHydronicn enumeration value.
Is that of any help?
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Hi Jeremy,
Actually when I open the Revit API help file from the Revit 2014 release I also see in the caption Revit Equinox API.
jeremytammik
Dear vchekalin,
Are you Victor? Welcome to the discussion group!
If you see such a message, you are using an obsolete version of the Revit SDK, with obsolete API documentation from the prerelease version of Revit 2014.
I would strongly suggest that you delete it before continuing to read this message  🙂
You can always download the most up to date version of the Revit SDK including all the API documentation from the Revit developer centre:
http://www.autodesk.com/developrevit
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
Yes, Jeremy, it's me:)
I didn't download SDK separately and just use the SDK what I found in the Utilites folder from Autodesk_Revit_Architecture_2014_English_Win_32-64bit_dlm.exe archive file. I downloaded this file from my ADN download page.
Thanks for the link to download the last SDK
Have a nice day,
Victor.
