Specific undo makes Idling event not fire anymore
simon_weinbergerC3JYQ
Repro steps:
  1. Start Revit
  2. Open new document
  3. Place a wall
  4. Double-click the wall to enter edit mode
  5. Ctrl+Z will exit the wall edit mode
Now, as long as that document is the active document, the UIControlledApplication.Idling event does not fire anymore. Changing the active document makes the Idling event fire again, but it's broken again when switching back to the broken document. Closing the document or restarting Revit fixes the problem.
I could reproduce this in Revit 2024-2026. I could not reproduce in Revit 2023 because step 5 does not exit the wall edit mode.
Exiting the wall edit mode in a non-undo way works just fine.
I haven't checked whether ExternalEvent is correctly raised, but you might want to do that.
ricaun
Wooo, that's a great bug. 🙁
The same problem happen if you edit a Group and use Ctrl+Z to exit the GroupEdit.
Revit now have this Document.IsInEditMode()
Probably every time the user exit any EditMode using Ctrl+Z the document enter in this bug state that Idling does not trigger, I know in Idling and ExternalEvent does not trigger inside the EditMode.
I tested the ExternalEvent and works after the EditMode with Ctrl+Z, only Idling that stop triggering.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
MarryTookMyCoffe
cool info I will add this to things that autodesk will never fix. Im 100% sure that my users will triger it in first week on my app release.  Searching for way to fix it will be another nightmare.
do not worry it only gonna take Autodesk 5 years to fix bug
ricaun
Yes, this issue probably gonna live forever inside Revit, now that Jeremy is retired is kinda hard to reach the Revit dev team.
ricaun
That's fun this issue combo with the missing Group ribbon Panel. The only way to exit the Group Edit mode when the Panel does not show is using Ctrl Z.
naveen.kumar.t
Autodesk Support
Autodesk Support
I have submitted the issue to our Engineering team. The reference for this issue is:
REVIT-241515Revit API: Specific undo makes Idling event not fire anymore
Please make a note of this number for future reference.
I’ll get back to you promptly once I receive their feedback.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
ricaun
Nice, I open a Problem Report in the Revit feedback: RVTPR-01369
With a video and code: https://youtu.be/cuvHTnE0-uE
