Sort Levels by Elevation
vanlion
vanlion
I customizing the LevelsProperty Sample so it is ordering the levels by Elevation. I already added the following line so everytime you open up the editor the levels are sorted by height
List<Level> levelsCollection = collector.OfClass(typeof(Level)).OfType<Level>().OrderBy(lev => lev.Elevation).ToList();
But i know it should also be possible to automatically update the datagridview when the editor is open. But i can't get it to work. any ideas? Thanks!
bindingSource1.Sort = "Elevation ASC";
BIM.Frankliang
Hi Vanlion,
     I think that you can try to use WPF MVVM to bind level name and level elevation to DataGrid.
 <DataGrid
           CanUserAddRows="False"
           CanUserDeleteRows="False"
           Margin="0,10"
           SelectionMode="Single"
           AutoGenerateColumns="False"
           CanUserReorderColumns="False"
           CanUserSortColumns="False"
           AlternatingRowBackground="#EBEBEB"
           Background="white"
           ItemsSource="{Binding ElevationList}">
           <DataGrid.Columns>
                <DataGridTextColumn Width="*" IsReadOnly="True" Header="ElevationName" Binding="{Binding ElevationName}" FontSize="12"/>
                <DataGridTextColumn Width="*" IsReadOnly="True" Header="ElevationValue" Binding="{Binding Elevation}" FontSize="12"/>
<DataGrid.Columns/>
</DataGrid>
You could create a class called ElevationModel which contains two properties: ElevationName, ElevationValue
Then, in ViewModel.cs, you could use ObsevableCollection<ElevationModel> ElevationList  binding with DataGrid.
Wish it is helpful for you 🙂
Best regards,
Frank Liang
vanlion
Hi Frank,
Thanks for taking time to help. I'm just starting with Revit and C#. So your example is a little bit difficult for me.
I hoped it was simple. Searched a lot in the internet but when you are new to C# it's hard to follow sometimes 😉
vanlion
I solved this one!
When implementing the sortableBindinList class and use that to list the levels it's working very well.
Didn't know it was that easy!
