Sometimes  Use Rebar API SetHookOritentation methond is invalid
ChGwo
ChGwo
When using the Revit project of the structural template, there is no problem creating reinforcement.
When using the Revit project of the building template, the created rebar cannot change the hook direction (SetHookOrientation is invalid), There is another problem, the created rebar plus the hook will produce many rebar shape family types.  Did anyone else find out?
What should I do?
jeremytammik
Can you achieve what you are trying to do manually through the user interface in the project based on the building template?
Jeremy Tammik
Developer Technical Services
The Building Coder
ChGwo
I tried, I can't.
ChGwo
sorry
