Some section views are missing in exported DWG files of these views
In Revit 2020, some section views are missing in exported DWG files of these views.Issue.png
jeremytammik
Dear Trinh Thanh Thuan,
Thank you for your query.
Is this a Revit API issue, or an end user question?
Are you doing anything programmatically yourself, or just using the standard Revit user interface?
If you are not doing anything programmatically, please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
If you are doing it programmatically, please be aware that the Revit API hardly ever supports any functionality that is not also available in the user interface.
Therefore, if this problem occurs in the UI as well as in the API, it would help most to solve it in the UI situation first.
It will always help to research the optimal manual approach to a solution first, before attacking the task programmatically.
I hope this clarifies.
Thank you for your cooperation and understanding.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
