Column Location not updated after column creation
Message 1 of 8
I've this strange situation:
I create a new structural column with this steps:
Step 1: creation
XYZ point = new Point(10, 0, 0);
FamilyInstance instance = document.Create.NewFamilyInstance(point, famSymbol, baseL, StructuralType.Column);
Step 2: rotation PI/4 = 90º from its own axis:
double rot = Math.PI/4;
XYZ vZ = new XYZ(0, 0, 1);
Location columnLocation = instance.Location;
LocationPoint pointLocation = columnLocation as LocationPoint;
if (pointLocation != null)
    Line axis = Line.CreateUnbound(pointLocation.Point, EjeZ);
    pointLocation.Rotate(axis, rot);
After this steps, the location point of the column is (0, 10, 0), not (10, 0, 0). Why?
Because after step 1, instance.Location.Point is the incorrect (0, 0, 0) instead of the correct (10, 0, 0) and, for a unknown reason, pointLocation.Rotate, rotates the column from its correct position (10, 0, 0) witth a a rotation axis positioned in the incorrect column position (0, 0, 0): the Location property is not returning the real location of the column!
I think this is an API error!
Replies (7)
Message 2 of 8
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous
1)Because after step 1, instance.Location.Point is the incorrect (0, 0, 0) instead of the correct (10, 0, 0)???
Ans: When your transaction gets completed the columns are placed properly in the document. since you are getting the location point before placing the column you are getting the location point value as (0,0,0).
2)the Location property is not returning the real location of the column!
ans: after rotating your column commit the transaction and try to get the column position.so that you will get the new position of the column.
I tried your code and it is working properly for me.
try using the below suggestions.
1)start the transaction.
2)place the family instance.
3)commit the transaction
4)Get the location point of the column
5)start a new transaction
6)rotate the elements
7)commit the second transaction.
8)get the updated location point of the column
and one more point
rotation PI/4  is not "90 degree" it is "45 degree"
I hope this helps.,
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
Hello, naveen.kumar.t:
I've tried using SubTransactions and I'm afraid your suggestion doesn't work
This is my modified code
TransactionStatus subStatus = TransactionStatus.Uninitialized;
using (SubTransaction st = new SubTransaction(document))
    try
        // create a new column
        subStatus = st.Start();
        FamilyInstance instance = document.Create.NewFamilyInstance(punto, famSymbol, baseL, StructuralType.Column);
subStatus = st.Commit(); // Rotation if (Math.Abs(rot) > .00001) { XYZ EjeZ = new XYZ(0, 0, 1); Location columnLocation = instance.Location; LocationPoint pointLocation = columnLocation as LocationPoint; if (pointLocation != null) { subStatus = st.Start(); Line axis = Line.CreateUnbound(pointLocation.Point, EjeZ); pointLocation.Rotate(axis, rot); subStatus = st.Commit(); } } return instance; } catch { if(subStatus == TransactionStatus.Started) st.RollBack(); return null; } } //SubTransaction
Of course, if I replace
with
Line axis = Line.CreateUnbound(punto, EjeZ);
it works fine, but that isn't my question.
Note 1: I've used SubTransactions instead of Transactions because I use this code with many elements and I want to group them in one Transaction
Note 2: You're rigth. PI = 180º, so 90º = PI/2
Message 4 of 8
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Here is the complete code to place the column element and to rotate the column element.
I think the problem may be with your subtransaction.
After trying using the below code if you still get errors.....can you please explain your errors in detail?
//Start the TRANSACTION
                  Transaction actrans = new Transaction(doc);
                  actrans.Start("Single");
                //Start SubTransaction 1
                //Get the COLUMN element and place it in the document
                SubTransaction subT1 = new SubTransaction(doc);
                subT1.Start();
                FilteredElementCollector Collector = new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Columns).OfClass(typeof(FamilySymbol)).WhereElementIsElementType();
                IList<Element> columns = Collector.ToElements() as IList<Element>;
                Element column = null;
                foreach(Element e in columns)
                    if(e!=null)
                        column = e;
                        break;
                FilteredElementCollector levelc = new FilteredElementCollector(doc).OfClass(typeof(Level));
                var ele = from Element in levelc where Element.Name == "Level 1" select Element;
                Level lev = ele.Cast<Level>().ElementAt<Level>(0);
                FamilySymbol Fs = column as FamilySymbol;
                XYZ loca = new XYZ(10, 0, 0);
                if(!Fs.IsActive)
                    Fs.Activate();
                //Place the column element
                FamilyInstance FI = doc.Create.NewFamilyInstance(loca, Fs, lev, StructuralType.Column);
                //Commit subtransaction 1
                subT1.Commit();
                //Start SUbTransaction 2
                //Rotate the column element
                SubTransaction subT2 = new SubTransaction(doc);
                subT2.Start();
                double rot = Math.PI / 4;
                Location columnLocation = FI.Location;
                    Line axis = Line.CreateUnbound(pointLocation.Point, vZ);
                //Commit subTransaction 2
                subT2.Commit();
                //Commit the transaction
                actrans.Commit();
I hope this helps.
Naveen Kumar T
Message 5 of 8
Message 6 of 8
The two first images were lost.
They are:
Before SubTransaction CommitBefore SubTransaction CommitAfter SubTransaction CommitAfter SubTransaction Commit
Message 7 of 8
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Are you trying to set a parameter value for the column parameters?
As I mentioned earlier, you can set an instance parameter value for an element which is not placed in the project.
and your element is created in the project once the transaction gets completed.
I think sub transaction won't do that and you are confused between transaction and sub transaction.
First, understand the difference between transaction and sub-transaction.
https://thebuildingcoder.typepad.com/blog/2013/04/transactions-sub-transactions-and-transaction-groups.html
https://spiderinnet.typepad.com/blog/2012/05/revit-net-transaction-transaction-and-subtransaction.html
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/Revit-API/files/GUID-BECA30DB-23B4-4E71-BE24-DC4DD176E52D-htm.html
To put it in a simple way
1)First, start the transaction(not subtransaction)
3)commit the first transaction.
(once the transaction gets committed the element is created in the project)
4)start a new transaction(not subtransaction)
5)rotate the elements
6)set Instance parameter value for the placed elements
(after the second transaction gets committed the parameters' values are changed and the elements are rotated )
This is the way to achieve what you want.
In your code
after the line
Instance=document.create.NewfamilyInstance();
you should commit the transaction to create the element in the project.
since your element is not created or placed in the project you are getting the location point value as (0,0,0).
after committing the transaction you will get the location point value.
Naveen Kumar T
Message 8 of 8
naveen.kumar.t
Autodesk Support
Autodesk Support
HI @Anonymous
In my previous post, I mentioned wrongly that
" you can set an instance parameter value for an element which is not placed in the project.
and your element is created in the project once the transaction gets completed."
actually, it is
you can't set an instance parameter value for an element which is not placed in the project
Naveen Kumar T
