some question.
some question.
some question.
In Revit API, I can find parameter by get_Parameter(BuiltInParameter paramId).
then, how can i find BuitInParameter Id by using parameter?
ollikat
Some answer.
I'm not sure whether I understand your question, but how about Id property of the Parameter? From the id object you can get the integerValue, which in turns corresponds the value inside the BuiltInParameter enum.
Hope it helps
Thanks. That is i wanted.
ollikat
Good!
Please remember also to mark this as "Solved" so that other forum users can easily see that there's a resolution for this issue (although the topic could be better...).
