DWF Export
DWF Export
DWF Export
Hi, I have wrote a program for export sheets to DWF. I used DwfExportOpion for some options but I need to set some options like "hide not linked view", "hide cut region"...
There is a way for make it?
How can I export to dwf using named printer setup?
thanks
Stefano
Joe.Ye
Hi Stefano,
It seems that the export options you want cannot be set via Revit UI command.
To get all named printer setup, you can call
Document.GetPrintSettingIds;
To use one of them as current print setting.
Document.PrintSetup.CurrentPrintSetting = targetPrintSetting;
You can change one print setting via methods/properties of class PrinParameters :
PrintSetting.PrintParameters.*** = ***
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
I will try it.
Hi, have you a VB example?
