Solid Form to Void Form
Hi!
I've created a form, by Loft, via Revit API: " loftform = doc.FamilyCreate.NewLoftForm(true, ref_ar_ar); ".
Then, I add some edges to that form, with the form.Add Edge Method.
After that, I want to convert the form to a void. I know that I can create the form being a void, setting the first parameter to false, however, if I do that, I am unable to add edges to that form.
Is it possible to set the form to a void after I created it?
Thanks in advance!!
Here's some of the code:
ref_ar_2.Append(geometry_arco1.Reference);
ref_ar_2.Append(geometry_arco2.Reference);
ref_ar_2.Append(geometry_arco3.Reference);
ref_ar_2.Append(geometry_arco4.Reference);
ref_ar_ar_2.Append(ref_ar_2);
ref_ar_2 = new ReferenceArray();
loftform2 = doc.FamilyCreate.NewLoftForm(true, ref_ar_ar_2);
if (tipo_I == true)
Options opt = new Options();
opt.ComputeReferences = true;
GeometryElement geoElement = loftform2.get_Geometry(opt);
Solid solido = geoElement.First() as Solid;
EdgeArray edge = solido.Edges;
Edge edge1 = edge.get_Item(1);
Edge edge2 = edge.get_Item(2);
Edge edge3 = edge.get_Item(3);
Edge edge4 = edge.get_Item(4);
Edge edge5 = edge.get_Item(5);
Edge edge6 = edge.get_Item(6);
Edge edge7 = edge.get_Item(7);
Edge edge8 = edge.get_Item(8);
Edge edge9 = edge.get_Item(9);
Edge edge10 = edge.get_Item(10);
Edge edge11 = edge.get_Item(11);
loftform2.AddEdge(loftform2.GetControlPoints(edge3.Reference).get_Item(1), loftform2.GetControlPoints(edge1.Reference).get_Item(0));
loftform2.AddEdge(loftform2.GetControlPoints(edge6.Reference).get_Item(1), loftform2.GetControlPoints(edge4.Reference).get_Item(0));
loftform2.AddEdge(loftform2.GetControlPoints(edge9.Reference).get_Item(0), loftform2.GetControlPoints(edge7.Reference).get_Item(0));
loftform2.AddEdge(loftform2.GetControlPoints(edge11.Reference).get_Item(1), loftform2.GetControlPoints(edge10.Reference).get_Item(0));
