Parameter not updating!
Bruno_Neves_Pires_Silva
I am trying to update a parameter in some pipes, but its not working, what I am doing wrong ? Please see my code below.
I've saw this post:
http://forums.autodesk.com/t5/revit-api/parameters-not-updating/m-p/4311799#M4140
But the solution provided by Augusto did not work for me, using the method "Set" instead of "SetValueString".
The parameter type is string.
public void app_Doc_Change(object sender, DocumentChangedEventArgs args)
Document doc = args.GetDocument();
ElementFilter filtro = new ElementClassFilter(typeof(Pipe));
ICollection<ElementId> col = args.GetModifiedElementIds(filtro);
if (col.Count == 0)
return;
string cod_str = "INTT:COD_MAT_COMPLETO",
cod_pre_str = "INTT:COD_PRE_MAT";
bool flag = false;
using (Transaction t = new Transaction(doc, "Atualizar diametro tubos"))
foreach (ElementId id in col)
Element el = doc.GetElement(id);
Parameter prm1 = el.LookupParameter("Size");
if (prm1 != null)
Parameter prm2 = el.LookupParameter(cod_str);
if (prm2 != null)
ElementType type = doc.GetElement(el.GetTypeId()) as ElementType;
Parameter prm3 = type.LookupParameter(cod_pre_str);
if (prm3 != null)
string valor = prm3.AsString() + "-" + prm1.AsString();
if (prm2.UserModifiable)
prm2.SetValueString(valor); //<= Value not updating!
//prm2.Set(valor); //<= I tried this and didnt work too.
flag = true;
if (flag)
t.Commit();
else
t.Dispose();
Revitalizer
Arnost said:
"Documents are always read-only during DocumentChanged events, thus no elements can be changed."
http://forums.autodesk.com/t5/revit-api/cannot-change-currently-created-element-parameters/m-p/57965...
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Oh my God! Thank you, Revitalizer. Of course, it makes all sense.
  But do you have any sugestion to me ? I need to change a parameter in the pipe if the diameter changes.
Revitalizer
you could use an IUpdater which reacts to geometry changes, to change a non-geometric parameter (which wouldn't trigger the IUpdater itself).
Cheers,
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Thank you again, Revitalizer.
   I am trying to implement this IUpdater, but is not triggering. Can you help me do find out why ?
public Result OnStartup(UIControlledApplication app)
TDiamChanger updater = new TDiamChanger(app.ActiveAddInId);
UpdaterRegistry.RegisterUpdater(updater);
ElementClassFilter filter = new ElementClassFilter(typeof(Pipe), true);
UpdaterRegistry.AddTrigger(updater.GetUpdaterId(), filter,
Element.GetChangeTypeGeometry());
return Result.Succeeded;
class TDiamChanger : IUpdater
static AddInId _appId;
UpdaterId _updaterId;
FailureDefinitionId _failureId = null;
public TDiamChanger(AddInId addInId)
_appId = addInId;
_updaterId = new UpdaterId(_appId, new Guid("6f453eba-4b9a-40df-b637-eb72a9ebf008"));
_failureId = new FailureDefinitionId(new Guid("33ba8315-e031-493f-af92-4f417b6ccf70"));
FailureDefinition failureDefinition = FailureDefinition.CreateFailureDefinition(_failureId, FailureSeverity.Error, "");
public void Execute(UpdaterData data)
 //Do something...
public string GetAdditionalInformation()
return "";
public ChangePriority GetChangePriority()
return ChangePriority.MEPSystems;
public UpdaterId GetUpdaterId()
return _updaterId;
public string GetUpdaterName()
return "";
Well, the main post about the parameter is solved, I will create another post about the IUpdater, and set this one as solved.
