SnappingService - What it actually does?
ollikat
ollikat
Hi
According to title, does anyone have any insight / experience. API Documentation doesn't say much :-(.
Thanks!
jeremytammik
Dear Ollikat,
Thank you for your valid query. I asked the development team for more information.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
jeremytammik
I heard back from the development team:
SnappingService provides snapping points and lines and is used for point clouds.
Jeremy Tammik
The Building Coder
ollikat
Hi
Thank you for delivering the information from the dev team.
Although I'm not quite sure am I still able to figure out the use case...but in the other hand, I'm quite incompetent with point clouds.
I was hoping to get some help in situation where I'm using the PickPoint() method and somehow to be able to know the coordinates where it is being snapping. But I guess it's probably not possible...(?)
jeremytammik
Maybe the PickObject method will give you what you need? It includes the pick point and other information in the Reference object it returns.
Jeremy Tammik
The Building Coder
