Showing error while modifying Rebar Type from D13 to D32.
shindeaa15
shindeaa15
I have placed Rebars using Revit API's and while placing I have passed Rebar Type as D13, D22 & D29.
For all above mentioned types Rebars are getting placed properly Manually as well as using Revit API's here images for properly placed rebars are attached as Image "RebarType D13-D22-D29".
But while placing rebars of Type D32 using Revit API's as well as manually we are getting error message as shown in Image "RebarType D32 Error".
For all above Rebar placement dimensions such as values of a, b, c, d, e are also shown in Images in Red Highlighted box.
Please find attachment and guide us so that we can able to place Rebars of Type D32 and D51 as well.
Thank you,
Akshay Shinde.
jeremy_tammik
Yes, seeing the same behaviour in the API as in the UI is perfectly normal and to be expected. That means that the API is functioning correctly as expected and reproducing the UI behaviour. Therefore, it is not an API issue, and the best place to ask for advice on optimal workflows and best practices to address this issue will be in the dedicated structural forum:
